You seem to be insinuating I think that a DMMCheck Plus is adequate to calibrate a DMM...
.. But if I measure 5 V on a calibrated DMMCheck and one DMM reads 5.00000 VDC and the other reads 4.99980 VDC, why should I not adjust the one which reads low?
Well, the problem with your argumentation is, that you compare references of different stability and accuracy, and in the end you indeed imply, that the DMMCheck REALLY could do the correct judgement, which of the two 34401A reads "correct".
That's the classical 'man-with-three-clocks' problem..
To get a more scientific approach, you have the DMMs, which are accurate to 15ppm in their 10V range, and stable to 35ppm/year. They disagree by about 40ppm on a 5V reading.
The DMMCheck on the other side is specified to have 70 ppm accuracy over 1/2 year, that's about 3 time worse than the 34401As.
So it's not directly possible to judge a 40ppm difference by a 70ppm accurate source; the service manual calls for a TUR of 5:1, not the other way round.
To achieve what you have in mind requires reference(s) of the same, or better stability class than the LM399, so that's the starting point for the LM399 and the LTZ1000 thread here in the forum..
If you have a bank of at least 3, let's say LTZ1000 based references, you can really start your drift analysis and really calibrate the 10V range of your 34401A, but you also need one initial calibration baseline of that uncertainty class, so maybe well below 5ppm, or so.
Then you need Transfer Standards, which precisely (<1ppm uncertainty) transfer your reference voltage to the needed values, like 7,xxx V => 10V, 10V => 1V, 100V, 1kV.
You asked, how this was done in the past, BEFORE the 5720A, or 3458A.
Well, these Transfer standards were the 720A KV divider, and the 752A reference divider, plus a stable 332A / 335B, maybe.
I recommend the Fluke book 'Calibration: Philosophy in Practice', where all this historic stuff is described.
But you really need such instruments, you can't solve that calibration problem just with scientific statistics.
Similar to Conrad Hoffman, I also built these devices on my own, in the beginning, because I also wanted to calibrate my 34401A, from 1990.
That's described here:
https://www.eevblog.com/forum/metrology/ultra-precision-reference-ltz1000/msg239666/#msg239666But I started directly with an appropriate approach, i.e. 2x LTZ1000, a precise 10/7 divider/amplifier (to 10.24...V, <0.2ppm ratio uncertainty by self-alignment) , and a 100:1 / 10:1 Hamon divider, also precise to < 1ppm ratio uncertainty @ 1kV. I also could once import the initial absolute uncertainty of < 10ppm from a 3458A in my company. All these self-built devices cost < 1000 € / $.
(Ok, sooner or later, this story escalated, similar to TiNs passion.
I propose that you better chose the appropriate devices, instead of fiddling with DMMCheck, or similar.
Concerning your approach to improve the relative uncertainty of references, I fully agree with you, but again under the precondition, that you use lowest possible stability for your initial reference ensemble.
That means, if you have 3 or more LTZ1000 references, you can measure the relative instabilities and estimate the absolute stability from that, (i.e. decide the 3-clocks-problem) so to have an uncertainty of that order of magnitude of about 1ppm also, if you once set a baseline.
But it's not feasible, to start with, say LM399s, as these will diverge much more, not giving the necessary stability for calibration of your 34401A.
If you once have that stable ensemble, then only you can add less stable references to your statistics, and use these additional baseline points to improve your uncertainty also.
These metrological techniques have been state-of-the-art, when Weston cells and these resistive dividers were common, and no Josephson Junction arrays were available.
I'm maintaining such a history of 4, up to now 9 voltage references, over about 9 years, which you requested.
I'd be interested in a statistical model, which analyses these relative drifts properly, and delivers properties of this ensemble, like probable overall stability, uncertainty, identification of 'stinkers' and handling of 'jumpers', after transport or temperature excursions.
PS: You obviously had some problems to measure low Ohm with your 34401As, consistently.
That probably may be caused by the well known 2W Ohm Offset problem, due to contaminated front/rear switches, but not by an improper calibration.
Frank
