Author Topic: Most stable VPG parts, HZ or VHP?  (Read 9022 times)
Online leighcorrigall
  • Nuclear Materials Scientist
Re: Most stable VPG parts, HZ or VHP?
« Reply #50 on: June 08, 2021, 12:53:36 am »
I have not used that TXSFR standard myself, but it looks like it directly plugs into your (and my!) 6581T for cal purposes. I believe the same spacing is also useful for a 3458a. It is a nice feature of the 6581 and 3458a that they allow this type of calibration.
If the meter calibration requires leads I guess the company sells an adapter of some sort (or you can make one).
Although this is completely off-topic, I think a better solution would be:
https://www.ab-precision.de/products/electrical-standards/
The product is from a forum member named Adrian Bernhard. He also makes shielded cables.  ;)
The following users thanked this post: TiN, ap, Anders Petersson
« Reply #51 on: June 08, 2021, 01:05:52 am »
Leigh,
Just curious do you know that Texas Components sells metrologycalibration standard resistors? Seems like a good deal given what you are going through? Or not.
http://webdirect.texascomponents.com/SearchResults.asp?Cat=1839
In retrospect, I believe this turnkey product is just a Vishay resistor inside a pre-assembled box, judging by the language and diagrams from the datasheet. If this is true, then it's likely cheaper just to buy the top-quality VHP100 and an enclosure.
PS, I replaced the Advantest R6581T front banana jack sockets with LowThermal 2758 Series binding posts so that I could avoid calibrating the system with banana plug connections. I might be overthinking things...
Offline kj7e
  • Damon Stewart
« Reply #52 on: June 13, 2021, 09:47:54 pm »
Leigh,
Sometimes that is exactly the case,  see this post for an example;
https://www.eevblog.com/forum/metrology/teardown-standard-resistors/msg891676/#msg891676
The following users thanked this post: leighcorrigall
« Reply #53 on: July 26, 2021, 08:47:37 pm »
I have decided to purchase a 4-wire lead 10 kΩ resistor Y473310K0000S0L (VHA518-11Z) with post-manufacturing operations (PMO) from Vishay Precision Group to act as a transfer standard for my Advantest R6581T 8.5-digit multimeter.
This may seem trivial, but I noticed last week that on the bottom of page 4 of the HZ Series (Z-Foil) resistor datasheet the actual part number for a 4-terminal resistor is 302075-11Z (Y4733). Vishay should really standardize their part numbers. I really don't understand why there are multiple order numbers for the same part.  :-//
