Hi everyone,
I bought a Nortel NTGS50AA at the end of last year... first testing worked ok... I also where able to setup LH on win and a communication.
2 weeks ago I decided to setup LH on a raspi and make long time tests to decide what I maybe log and how to manage this logs.
I where able to run the device over 6h without any problems and wrote at least a 4h xml logfile (my son decided to try this
All this was "on the fly" and worked quite good enough to try to run a long time test in a lab enviorement to compare it with stuff there.
I decided to move the epuipment and after finding a temporary position for the GPS antenna the system in generel worked for ~3h.
I keep the system running and wanted to know how it develped over night.
Now the problem:
Next day I found the raspi stuck with no additional data... thought it was because of missing additional RAM or storage possibility of the raspi, which is running only from SD card.
Restarting the raspi doesn't fix it.
I take the trimble from power and restarted it.
Everything than seemd to work again... but only for less than half an hour... it stucked again.
A closer look shows me the red fail LED of the device (didn't noticed it before because of orientation of the device.
today I assembled it again at home and it worked for at least an hour... until it "crashed" again
ok, I had only 4 sats (sometimes 5 or 6) and in last attempt it decided to not that the saved position is bad, but I am sure that can'T be the problem
I attached some pics from the last screen which heather displayed.
Remarkable is the jump rigth before the end of the plot... looks like the system want to adjust something but where not able to do this and set it into halt and failure mode.
Any suggestions what I can check or what went wrong?
