Author Topic: Russian Transfer Standard B1-30  (Read 2416 times)
Offline zhtoorTopic starter
  • Country: pk
« on: December 15, 2017, 08:01:58 pm »
Hello,
any body with teardown or other information about this ref?
specs:-
The reproducible voltage is 9 ± 0.45 V.
The instability of the reproducible voltage for every 1000 h at a temperature of 20 ± 5 ° C is 0.0005%.
Additional temperature error is 0.000025% / ° C.
The time for setting the operating mode is 4 hours.
The output resistance is 15 ohms.
Power consumption - 8 V ??· A.
The overall dimensions are 151 × 86 × 79 mm.
Weight - no more than 1.2 kg.
regards.
-zia
Online wraper
  • Country: lv
Re: Russian Transfer Standard B1-30
« Reply #1 on: December 15, 2017, 08:37:25 pm »
« Last Edit: December 15, 2017, 08:39:35 pm by wraper »
The following users thanked this post: zhtoor
Offline Mickle T.
  • Country: ru
« Reply #2 on: December 16, 2017, 06:32:17 am »
I have a two V1-30. They are rather old and noisy (1 ppm p-p 0.1-10 Hz), but fairly stable and gives ~1-2 ppm/3 years drift rate in power off mode.
The following users thanked this post: zhtoor, beanflying
Online beanflying
« Reply #3 on: December 16, 2017, 08:04:36 am »
Wonder how much of the noise comes from the Transformer and power supply inside the same box?
  • Country: pk
« Reply #4 on: December 16, 2017, 09:12:32 am »
thanks Mickle T.
a wonderful design for the time...
regards.
-zia
