DOT-5 and DOT-5.1 == brake fluid for my Citroen car?
https://www.startmycar.com/citroen/guides/brake-fluid
Hello
Yes that the cheapest silicone fluid available , far cheaper than silicone fluid use in lab thermal bath and available from a lot of suppliers in small can as that a car maintenance product , only 5.1 is silicone base all other are not silicone base .
Regards
OS
Other way around. Dot5 is silicone base.
I’d be wary of using any brake fluid, even the silicone ones can contain unwanted additives for corrosion protection, wear or moisture absorption. Without extensive testing it is hard to say if the possible additives are for bad or good.
Medical grade white oil is quite safe bet that it doesn’t contain ”artificial additivies”
[/quote]
HelloI have provided this fluid ref as a cheap alternative for DIY resistor / experiments and nothing more.
I use this fluid as oil bath fluid for metallurgy light alloy sample since years without problems at temp up to 150 deg C
5.1 is a mix of
Tris[2-[2-(2-methoxyethoxy)ethoxy] ethyl] orthoborate which a triester so a thermal fluid you can also have in '' oil heating system '' as electrical radiator but also hydraulic fluid ...
minodipropan-2-ol so a stabilizer to adjust viscosity
Brake fluids are safety products and homologated by car brakes company for corrosion , seal compatibility ...
Changing oil of a reference resistor ( and probably the seals ) is a very rare operation regarding the price of a Tinsley resistor and the fact that a quite rare equipment too so no reason to try to save pennies on the oil specification and avoid to use the specified oil from Castrol.
A last point , mixing oil can be a risky trial as not all oil are compatible so that far better to stay with the original specification
Another technical fact to know : Engine oils are full of additives and shall be avoided for any experiments.
Regards
OS
