I am aiming to reconfigure a circa 1985 Optronics 83DS precision current supply, as in common use in optical related labs as a reference lamp supply. Optronics have no remaining documentation on it, and I can't find any from when this was used. The internal electrical schematic should be fairly simple to reverse engineer, but I thought I would ask if anyone has anything related to this, or even any later model (83A) ?
The front panel allows a constant current from 1mA to 9.999A to be set, but I don't even know the max voltage range spec yet although it's likely to be up to about 120V. The only known specs (I think) are +/- 0.05% current accuracy and the same for line/load regulation. So I may be able to retain its use as a lab precision current supply and see how good it is.
Unfortunately the mains AC is 115V, and it is direct rectified and brute-force cap filtered, so not very elegant. I could end up running it through a step-down/isolation transformer, but I may be able to feed it from an alternative mains-isolated DC supply, and just live with a restricted output voltage and current span.
