I'm not familiar with the OSC5AB02 OXCO,
You might want to find the specification for the OSC5AB02's EFC and the expected performance of the OXCO and then you'll be able to do the math.
For example, put the Vref and the divider into the LTspice, and do a MonteCarlo analysis with the resistor's and potentiometer TCs.. You will get an idea how it will perform.
..This can be used for error propagation estimates. With a 10 K ambient temperature change the 4 ppm/K reference will give you less than 80 uV error at 2 V..
I am designing a 10MHz and 1pps standard for my bench and other projects. It will use a surplus OSC5AB02 OXCO. I have a GPSDO, but want something I can use where GPS is not an option, like my lower ground floor (basement) work area.
Any suggestions? Am I overthinking this?
Like the reply from MIS42N, I have high stability OCXOs in test equipment that is only used occasionally. If I check the ovens in that equipment it will be surprisingly “unstable” unless it has been left powered for several hours. For calibration it should be powered for at least 24 hours. The ovens are fitted to Racal equipment and are option 04B.
The specification is quite detailed:
The ageing rate is 5 parts in 10^10 averaged over 10 days after 3 months continuous operation.
Temperature stability of +/- 6 parts in 10^10 per degree centigrade averaged over a range of 0 to +45C
Warm up to +/- 1 part in 10^7 within 20 minutes.
I would look to use a GPSDO rather than a free running OCXO. If you can install an outdoor antenna and a low loss coax feed to the basement, you won’t then have to bother about accuracy. Check coax loss at 1.5 GHz, it is quite significant but the outdoor “mushroom” GPS antennas tend to have a high enough output to cope with several metres of coax. Some roof mounted antennas seem to be over priced, the Leo Bodnar one with 30m of coax costs 3 times the cost for the same antenna with 10m of coax (they only use common/cheap RG58 coax).
SJ
stability should be at least 0.05mV per year , so construct divider , as coarse ,and fine adjustments , fine need outside and minimal impact per temp change.
RC filter for Vref chip advised
would be advisable to keep Vref chip close or direct contact with OCXO, as a plastic SOIC , it will minimize temperature and humidity effects.
An antenna on the roof here is not an option. I don't have permission. I might be able to get enough signal if I stick it out the window. I'll have to see if can gen enough satelites.
an EFRATOM FRS Rubidium clock,
