tuned such ocxo to -12 , it dropping to around -10 in 6 month, so approx -9 per year
but this is AC cut
Vref to OCXO:
i shunt 68uf polymer then few ceramic - minimize jitter
stability should be at least 0.05mV per year , so construct divider , as coarse ,and fine adjustments , fine need outside and minimal impact per temp change.
RC filter for Vref chip advised
would be advisable to keep Vref chip close or direct contact with OCXO, as a plastic SOIC , it will minimize temperature and humidity effects.
OCXO stable more less after around 2 Month, Vref chip .... can be 6 months, physically finalize a place where it should be , then do adjustment ; movement can slightly affect output, or significantly by gravitational waves. depend on axis positions.
my personal construction was - whole board in 2 inch Styrofoam box - minimize outer temperature affect to Vref chip, volt dividers, and OCXO itself.
TinyPFA are very useful tool for stats , adjustments.
SC cut are bit better
