Author Topic: Powering a REF IC with another REF IC  (Read 1569 times)
Offline ali_asadzadehTopic starter
« on: October 09, 2016, 09:14:50 am »
Hi
Does this idea give us some benefits? suppose we use a 5V ref IC to power a 2.5V REF IC? Does it increase the performance of the 2.5V reference?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline Kleinstein
Re: Powering a REF IC with another REF IC
« Reply #1 on: October 09, 2016, 10:06:41 am »
Having a stable supply for a reference can increase the performance. However with modern reference chips the supply does not have to be that stable. So no need (and no more significant improvement) to be better than standard regulators.
Many circuits for shunt references even use the reference itself so set the current the reference is powered with.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: October 09, 2016, 10:09:17 am »
Read the line regulation specs in the datasheets.
My guess is that temperature and ageing are more significant factors.
Day Job: Mostly LEDs
Offline David Hess
  • DavidH
« Reply #3 on: October 09, 2016, 10:01:13 pm »
It will increase the power supply rejection ratio but you can do the same thing by powering the reference from its own amplified output which is commonly done with zener diode references.
