Author Topic: Precision Resistors - General Thread  (Read 34325 times)
Offline sahko123
  • Country: ie
Re: Precision Resistors - General Thread
« Reply #125 on: May 20, 2022, 09:38:54 pm »
Is there any particular reason certain oils are used? Is because of corrosion issues? Or even humidity issues?
Asking for a friend
Offline leighcorrigallTopic starter
  • Nuclear Materials Scientist
« Reply #126 on: May 20, 2022, 10:03:13 pm »
Some oils spoil or are corrosive because of contamination. Other factors are heat transfer and high-resistance insulation.
MASc, EIT, PhD Candidate
Online bsw_m
  • Country: by
« Reply #127 on: May 21, 2022, 12:35:47 pm »
I has measure diameter of glass insulated cast microwire from 100 MegaOhm resistor.
Wire without insulation: 2um  :o
Wire with glass insulation: 14um
Sorry now I cannot take the microwire photo from my microscope when I don't have the photoattachment for my microscope.
P.S.
I try take photo from eyepiece with phone camera. Quality not good, but..
625x magnification.
« Last Edit: May 21, 2022, 01:00:21 pm by bsw_m »
Online TimFox
« Reply #128 on: May 21, 2022, 02:09:54 pm »
Before I retired, we used Shell DialaTM transformer oil for insulating high-voltage supplies.
So far as I could tell, it was basically pure motor oil, with BHT (or similar) added to retard oxidation.
Butylated hydroxytoluene is an anti-oxidant, whose use in food is controversial.
(For high-voltage purposes, it was necessary to pump a vacuum on top of it to remove bubbles.)
The following users thanked this post: leighcorrigall
