Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Metrology
Relay contact material selection
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Relay contact material selection (Read 2609 times)
IconicPCB
Super Contributor
Country:
on:
January 17, 2017, 07:22:12 am »
Looking for a recommendation for relay contact material for minimum thermal EMF and low current performance
Either relay contact materials or perhaps relays.
Logged
Echo88
Frequent Contributor
Country:
Re: Relay contact material selection
Reply #1 on:
January 17, 2017, 07:54:48 am »
Please take a look at the following threads which answer your "which relay?"-question:
https://www.eevblog.com/forum/metrology/measurements-on-emf-error-of-switches/
https://www.eevblog.com/forum/metrology/metrology-grade-scanner-card/
https://www.eevblog.com/forum/projects/diy-low-thermal-emf-switchscanner-for-comparisons-of-voltage-and-resistor-stand/msg610755/#msg610755
https://www.eevblog.com/forum/metrology/low-thermal-emf-scanner-and-ordinary-non-latching-relays/
Logged
IconicPCB
Super Contributor
Country:
Reply #2 on:
January 17, 2017, 09:18:23 am »
A full bottle
Logged
IconicPCB
Super Contributor
Country:
Reply #3 on:
January 21, 2017, 11:39:20 pm »
Seems relay coil power dissipation is an issues.
A "spike-and-hold" driver could reduce the power dissipation significantly.
Logged
SeanB
Super Contributor
Country:
Reply #4 on:
January 22, 2017, 04:57:05 pm »
Bistable relays perform best with low thermal EMF issues, but are expensive, and you will have spikes with the suddenly heats coils during actuation.
Logged
IconicPCB
Super Contributor
Country:
Reply #5 on:
January 22, 2017, 09:44:46 pm »
Spike and hold drive is intended to drive conventional relays with the view to minimising heat within the relay assembly.
Spike voltage = required voltage to pull in the armature
hold voltage -= required voltage to hold the armature once relay has been actuated
hold voltage < spike voltage
dissipated power reduction = proportional to difference between the squares of two voltages
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Metrology
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
