FWIW, 3456A has been on since February, 16. There are some preiminary measurements with non-calibrated resistors.
100R, 1k, 10K are Vishay Z-201, now called Y1453. These are the epoxy body ones, 0,01% tolerance and supposedly .2 ppm TCR.
100K is Vishay S102K, now called Y0062, also epoxied, 0.01% tolerance and supposedly 1 ppm TCR
1M is RESI MMFR5215B1M00V9, 0.1% tolerance, 5ppm TCR
10M is Ohmite MOX-750231005FE, 1%, 25 ppm TCR
1G is Ohmite MOX-2-121007FE 1% 50 ppm
Measurements taken at 6 digits, 100 NPLC, Auto ZeroOn, autorange. 20ºC
| 100R | 1K | 10K | 100K | 1M | 10M | 1G |
2W | 100.4031 | 1000.703 | 10.00050+3 | 100.0023+3 | 1000.039+3 | 9.98653+6 | 1033.732+6 |
2WOC | 100.3818 | 1000.671 | 10.00046+3 | 100.0021+3 | OL | OL | OL |
4W | 99.9975 | 999.947 | 10.00014+3 | 100.0018+3 | 1000.038+3 | 9.98674+6 | 1032.535 |
4WOC | 99.9995 | 999.947 | 10.00013+3 | 100.0018+3 | OL | OL | OL |
5 Volts DC from DMMCheck: 4.99947-4.99955
5 Volts AC " " 5.00083-5.00095
Without having these resistors calibrated, I don't know if it's in spec or not, but at least it seems it's not jumping like a goat.
