I need to carry out a test that involves something being dropped and an accelerometer measuring the impact and recording it.
The test specification seems to have been created by an industry body rather than a specification body so feels a bit like they are not sure how to explain it.
The system requires 1kHz of bandwidth, 10kS/s and the results needs to be low pass filtered with a -3dB filter @30Hz. There are some filter ripple requirements, at this point given that a -3dB filter is a simple RC filter I assume the ripple stuff is for digital filtering of the data.
So I need an accelerometer with at least 1kHz of bandwidth and a low pass filter of 3dB. Given the brevity of the test I was considering using an oscilloscope to capture the waveform. I have a picoscope with 250MS/s so that is 10kS/s satisfied but I would put the signal through a physical RC filter so that sampling rate comes after the filter. But as the result is to be capped at 30Hz and the scope has 250MS/s it's the same thing?
If my sensor has a higher than 1kHz bandwidth should I filter it to 1kHz ? or maybe 10kHz, the bit that I don't understand is that if this is all being filtered to 30Hz then why all the other numbers? Nothing faster than a 30Hz sine wave will pass that filter and unless a square wave were less than 3Hz it would not be accurately shown.
