Author Topic: SIGLENT SDG1025 FAIL  (Read 3375 times)
Offline ekrzychooooTopic starter
« on: July 11, 2017, 01:27:40 pm »
Hello
The SIGLENT SDG1025 generates poor performance when changing frequencies.
Please watch this movie and write what you think.
Are your generators other than SIGLENT eg RIGOL having the same problem?
The information has already been sent to SIGLENT.
Now I'm waiting for an answer.
Regards
Christopher.
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
Re: SIGLENT SDG1025 FAIL
« Reply #1 on: July 11, 2017, 04:20:00 pm »
I never had such issues on my SDG1025. If it's a thing, mine has to go anyway, because I want one with lan.
I don't have acess to it, but I will look into the problem onve I have.
http://rbastlerblog.jimdo.com/
Gamma spectrometer works. Now some yellow crystals need regenerating and testing.
Offline Muxr
« Reply #2 on: July 11, 2017, 05:06:29 pm »
I haven't experienced this with my SDG1025 but I can try to reproduce it tonight. I do remember updating firmware on mine when I first bought it because it had some bugs, but I can't remember what those bugs were of the top of my head.
« Reply #3 on: July 12, 2017, 10:12:26 am »
Here is the next movie.
Switch to text, in English
https://youtu.be/ulQ1FglQGPY
Offline nctnico
« Reply #4 on: July 12, 2017, 10:22:05 am »
This is normal behaviour for many (if not all) digital function generators. If you need defined behaviour then use the burst function combined with a trigger.
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #5 on: July 12, 2017, 10:23:17 am »
What firmware version do you use ?
« Reply #6 on: July 12, 2017, 10:26:15 am »
I use 1.01.01.39R2
« Reply #7 on: July 12, 2017, 10:28:32 am »
It is not normal. In RIGOL generators everything is OK
I use class C++
pseudocode
for(f=Fstart; f<Fend; f += delta){
    set_SDG1025(f);
    Sleep(100ms);
    measurement();
I need eg 500 samples.
Function measurement(); Shows nonsense.
« Last Edit: July 12, 2017, 10:36:07 am by ekrzychoooo »
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #8 on: July 12, 2017, 11:32:03 am »
No.
(Rigol DG1032Z here)
« Reply #9 on: July 13, 2017, 10:11:55 am »
« Last Edit: July 13, 2017, 10:52:33 am by ekrzychoooo »
Offline tautech
« Reply #10 on: July 13, 2017, 08:52:47 pm »
I think you must use the Sweep function to side step the frequency change glitch.
Avid Rabid Hobbyist
