Author Topic: Signal Generator in the MHz range  (Read 2021 times)
Offline lordvader88Topic starter
« on: April 14, 2017, 11:24:14 pm »
There is a new force in the GALAXY( The is a signal Generator on ebay for 105CAD (~70US) and its rated up to 24MHz and around 14Vpp I think.
I just want this as a hobbyist. I have a home soldered kit that does up to about 8kHz wit its capacitors. I look forward to seeing what that chip can do with different timing caps.
Here's a review, I plan to get 1.
plasma rifle, 40mW class
« Last Edit: April 14, 2017, 11:26:14 pm by lordvader88 »
The following users thanked this post: enut11
Offline enut11
  • Love building/modifying/restoring test equipment
Re: Signal Generator in the MHz range
« Reply #1 on: April 15, 2017, 07:23:53 am »
Excellent demo of this very versatile and inexpensive frequency generator @lordvader88. Perhaps in the wrong section of the Forum?
enut11
an electronics nut from wayback...
Offline Vgkid
« Reply #2 on: April 15, 2017, 07:36:52 am »
Nice job.
Ask a mod to put it in the test gear section. It will noticed there more.
Offline NottheDan
« Reply #3 on: April 15, 2017, 08:14:11 am »
Offline chrisalbertson
« Reply #4 on: April 19, 2017, 06:26:24 am »
I don't think the leak is fixed nor will it be fixed.  Also, I think it is a non-problem if you follow common sense procedures like first connecting the generator's signal ground to the DUT's signal ground.
I have one of these on order.  Got a tracking number.  It shipped from a US warehouse so I should have it in the few days.
Would you believe, my current RF signal generator is a vacuum tube unit.  This will be a step forward in technology.
