Author Topic: Sinclair DM350 calibration  (Read 2665 times)
Offline zertoTopic starter
« on: December 25, 2019, 02:55:38 pm »
Hello,
I have extracted my first multimeter from the attic and it is still working (I bought it in the early eighties !). A quick check on voltage measurement shows a 5% error over 2.5, 5, 7.5 and 10 V  reference voltage. I would like to try to calibrate it so I am looking for the Sinclair (Thurlby Thandar Instruments) DM 350 digital multimeter service manual, anyone who could share it with me ? that would be fantastic !
I found a web site with the manual but it is rather complicated to download it... even the registration to the web site is quite complicated, I am not sure what they are asking for.
Regards
« Last Edit: December 25, 2019, 03:05:50 pm by zerto »
Re: Sinclair DM350 calibration
« Reply #1 on: December 25, 2019, 03:04:12 pm »
adding some images...
« Last Edit: December 25, 2019, 03:10:07 pm by zerto »
Offline Andreas
« Reply #2 on: December 25, 2019, 09:52:35 pm »
Hello,
at that time only few chips were used for DMMs. (ICL71xx)
I would look at the 28 pin Chip number and a data sheet for it.
Then adjust the reference voltage to the value of the data sheet (100.0 mV or 1000 mV)
This will help at least for the DC-voltages/currents.
But before I would clean/reseat the contacts of the chips in the socket.
with best regards
Andreas
« Last Edit: December 25, 2019, 09:54:41 pm by Andreas »
The following users thanked this post: zerto
« Reply #3 on: December 26, 2019, 06:09:17 pm »
Thanks for the tips, the chip is a MP7138A, but I could not find the datasheet yet.
I will cleanup the contacts as you are suggesting and check the reference voltage if I can get the service manual.
Best Regards
Online iMo
  • Country: bt
« Last Edit: December 26, 2019, 06:36:20 pm by imo »
« Reply #5 on: March 21, 2020, 02:45:15 pm »
I wanted to share the great outcome of this topic:
After cleaning the main chip, the switches and the rest of the board using a contact cleaning spray, and with the help of the service manual I have been able to recalibrate the unit at better than 0.1% error on DC voltage ! I am really happy to be able to reuse my first multimeter, being confident on its accuracy
thank you all for the tips :)
The following users thanked this post: Andreas
