Deeply back in this thread, there is a table of measured 'attenuation' factors for the different resistors. Any change of one of the 70k is attenuated by 250, the other by 1000, so forget about the datasheet. I think, R2 and R3 designators are referenced to latter schematic.
Also keep in mind, that hp used thin film only for these resistors.
So one of these should be better, less timely and T.C. drift .
I also recommend to lower the 15k to 12..13k for best stability.
Don't forget: Noise is not everything
(... Physics is everything!)
Frank
