I've been meaning to check my soldering irons.
Hobbying a bit and i by now i collected weller vhs45, hakko 888d, ts100 and one of the aoyue hot air stations.
What prompted me to start thinking of this is the weller which started to have issues with male part of din conenctor so i it was randomly not heating as i moved the lead. Before I figured out what was wrong i was looking into pcb contacts and thought that it just went out of calibration whatever crude one it is with it's potentiometer. So I found a little trimmer in there and cranked it up. Of course now i know it was heating well it just hd connections problems, so how do I get it back and while I am at it, i can check other ones too just to get them into the same ballpark.
So naturally I got my aneng 8009 which is the only multimeter i have with a probe to check. It shows much lower temperature with it's ugly, claim to be, k-type probe. So i borrowe a fluke 568 gun thermometer which can't even see the iron tip with its sensor, but also has a k-type probe whics also shows like 100°C lower than my hakko 88d display.
So what gives? I stumbled upon this video also where Big Clive shows probes not working
I don't want to spend 300$ on a hakko tester. I don't really need to know the temperature.
The thought crossed my mind that solder melting points should be quite a reference like 187°C for SnPb and 213°C for SnAgCu or whichever numbers are correct.
Anyone tried to use cheap hakko ebay ripoffs? Did you guys ever try to measure your irons?
