Is there such thing as an inexpensive AC
stable power supply? In the devices I'm testing, the +/- 0.5% variation in mains voltage is causing about a +/- 1.5% variation in measured output. I'd like to eliminate that variability.
The closest thing I've found is the
Instek APS-7050E, but (a) it's still over US$1600, and (b) I can't quite tell if it would actually be an improvement from its specs. (I'm not sure whether its line regulation spec of 0.1% of full scale is 0.1% of 120V or 0.1% of 500V, and whether that's just accuracy rather than stability.)
Is there a different or a better solution? The DUTs are generally under 120W max, and usually quite a bit lower.
Would a double conversion UPS tend to be more stable? These seem to be a bit more affordable, at $600 for the
Tripp Lite SU700XLCD or $750 for the
Eaton 9SX700, but I don't know if they're necessarily more stable either.
I've even heard discussions of feeding an AWG sine wave into an audio amplifier to produce 120V, but I'm not sure what specs I'd need in such an amplifier or what kind of load it could support.
I'm fine with something secondhand, so long as it produces a steady voltage and frequency even when mains fluctuates.
