I recently obtained a X99 Symmetricom. Although I do not have a x72, it seems to be the same in appearance, features, and outputs with a different label.
Hooking it up to lady heather shows where some of the differences are. The firmware does not return the “r>” prompt that lady heather 6.14 was designed for, the second is the baud rate defaults to 9600, and the output is data is not in hex.
By the way Mark Sims, you did an awesome job on putting in all the support for it!
I’ve taken the source code from KG7NUX (4.16.1), and have spent a few hours making “minimally” non-destructive changes to correct the support for the X99 that I have.
After doing an initial disciplining against 3 different sources with saving procedures similar to the SA.22c I outlined in another thread using lady heather. The performance, drift, and accuracy is comparable with the SA.22c that I own.
So the questions I have for those reading this:
1) Does anyone out there have the user's manual for the X99 Symmetricom?
2) Does anyone with a X72 have the ability to extract the firmware loaded on the X72? Can you share it?
3) Is anyone interested in the changes I’ve made to Lady Heather? I have it working in Linux currently but if someone wants to provide some instructions on building for Windows I can give it a try. I’ll also need to test it against the SA.22c to make sure all the features I used are still good.
The source changes that support the X99 are now on github:
https://github.com/randomthings00/ladyheatherI’ve also included a picture of it during one of my non-calibrations testing for those interested.
[Updated: with github link]
