For such a tempco test, I have the following suggestion: Have the starting point as the high/low temperature, and don't do temperature control. If you have a controller, it will do on/off control and upsets your measurement. Just isolate the setup, place a thermal mass in it if necessary, measure temperature at the beginning and switch of cooling/heating, and let it reach room temperature. The results will be much less noisy and easier to curve fit them.
And that being said, regular wirewound resistors will easily be ~200ppm/K, if accuracy matters you need high precision ones made exactly for this.
