Saturday i tested one of those and got a 1.7 uV effect when "heating" one end with my fingers. That was a Dale RS-02B wirewound resistor. As far as i understand that is a good result, less than the 3 uV they claim in one of the Vishay videos.
There is nothing uniform in that experiment. For a first resistor, light is shining to the side...
How do you distinguish the thermal EMF caused by the structure inside the shunt from the thermal EMF caused by the metal joints/junctions between resistor terminals and the conductor? On the other hand, the guy in that video presents his resistor with ZERO thermal emf with the same (lets assume) assymetrical setup (regarding the heating gradient). If hes not faking, he must have a recipe for solder connections with zero thermal emf both for resistor to PCB trace and for PCB trace to test wire. Is it pure tin? Tinned wire, tinned resistor terminals, tinned PCB traces? Could it be that simple?
Edit: Just another thought. I am now wondering why all these reference designs around the LTZ1000 do use gold plated PCBs. Copper to gold has 0.5µV/°C, but gold to most available solder alloys has 3-5µV/°C. This would mean that you really need to take care about the positioning of every pad of the critical components. Why don't they just use chemical tinned PCBs as they are widely available even from pool manufacturers?
Look at the video again, you can clearly see bright spot is not in the middle. Halogen light is a spot source and it definitely didn't heat uniformly, INCLUDING connection wires going to microvoltmeter. Light is not in the same spot for other two resistors..
That is why I said that he had to have immersed them in heated Galden or mineral oil and then see what happens.. I bet you results wouldn't show much difference.
Second thing, Seebeck voltage DOESN'T appear across different metal
connections. It appears across thermal gradients in material, and if you connect two dissimilar materials, two sides won't be the same and won't null differentially.
Difference will be in both Seebeck voltage coefficient for the metal, and it thermal resistance, making temperature gradients different. In sensitive circuits soldered joint might make more difference if pads are different surface and have different amount of solder than what solder you used. Any imbalance will show, dissimilar materials only make thing more visible.
So if you have copper trace, solder pad with solder to one side of resistor, resistor, other side soldered to solder pad going to copper trace, make it all symmetric, make all of that on aluminum PCB, and than, you put that PCB on heated plate larger than PCB and measure that... I bet you you won't see much of thermoelectric voltage, regardless of what resistor you solder in.
Full metal foil resistors, with metallic connection to pads will conduct temperature better than small ceramic resistors made from ceramic NOT designed for thermal conductivity. So any thermal differences will be more visible. So resistor that conducts temperature better will be less sensitive to Seebeck effect. And that applies to ANY resistor made to be current shunt, they all are designed for that. He compared two unspecified resistors with expensive dedicated metal foil shunt resistor. I guess it would be better comparison to compare to other dedicated shunts....
It is shady marketing video. Which is shame, really, because those metal foil Vishay resistors are top quality stuff. No need for misleading marketing.
Best regards,
