Author Topic: TI's new RES60A makes high-voltage attenuation easy!  (Read 1403 times)
Offline laichhTopic starter
  • Country: my
« on: October 22, 2024, 03:25:25 am »
An alternative to Caddock, Vishay, & VPG divider.
https://www.ti.com/product/RES60A-Q1
The following users thanked this post: RoGeorge, ch_scr, the Chris
Offline mendip_discovery
Re: TI's new RES60A makes high-voltage attenuation easy!
« Reply #1 on: October 22, 2024, 05:32:41 pm »
Tempting solution for an issue I have of measuring output of some Hipot testers, it states it is happy up to 4k for 60 seconds. I wonder if it could be pushed to 5kV without long term issues.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Offline HalFoster
« Reply #2 on: October 22, 2024, 05:47:16 pm »
Very nice!  And they have a related low voltage part with dual matched dividers as well: https://www.ti.com/product/RES11A
Hal
--- If it isn't broken... Fix it until it is ---
Offline razvan784
« Reply #3 on: October 22, 2024, 07:19:54 pm »
Tracking TC 1 ppm/K typ., 5 ppm/K max.
Voltage Coeff. 2 ppm/V typ.
Very nice.
I see one slight drawback, the 15% absolute tolerance, which does allow you to claim >10M input resistance, but not 10M precisely.
Long-term drift and humidity sensitivity might be some other issues.
  • Country: my
« Reply #4 on: October 23, 2024, 02:53:51 am »
Very nice.
Voltage coefficient of 2 ppm/V could be an issue! Imagine up to ±2 V of measurement error when measuring a 1000 V source, that is between 998 V ~ 1002 V, or 3½ digit resolution limited just by the voltage coefficient alone.
In contrast, the similar 10 MΩ voltage divider from Vishay & Caddock has a voltage coefficient of less than 0.02 ppm/V.
https://www.vishay.com/docs/60043/cns471.pdf
https://www.caddock.com/online_catalog/mrktg_lit/TypeHVD.pdf
https://www.caddock.com/online_catalog/mrktg_lit/TypeUSVD.pdf
Offline Kleinstein
« Reply #5 on: October 23, 2024, 07:07:41 am »
The voltage coefficient would be a problem. However the main nonlinearity is usually more a thermal thing and thus more a square law, not a linear part as implied by giving ppm/V.  The thermal effect is a principle limitation for such a small case - for improved accuracy some better DMMs use additional heating to compensate. For the thermal effect it also make a difference which voltage is assumed (e.g. 500 V , 1000 V or maybe 1700 V). The RES11 data-sheet shows using a rather high voltage used for the test of the voltage coeffcient.
For the Vishay and Caddock resistors the voltage coeffient given in the data-sheets may be just the the linear part, so excluding the direct thermal effect on the TCR. A linear effect is possible from uneven heating and thermal EMF. So the numbers may not be comparable.
A problem with the high voltage dividers from Ti is there ESD rating - when used for a DMM input, they would need extra ESD protection !  Once damages by ESD the resistor may no longer be able to withstand a high voltage. So the dividers are really made to be used in a more fixed circuit, like a high voltage power supply or checking on the high voltage battery.
After all the divider is a rel. small and cheap part ($2 range), not really made for highest performance. The plastic case also makes it possibly sensitive to humidity effects. For high performance applications the divider ratio is also a bit large - one would like more 1:100 and I would even like 1:50.
It is still nice to see a new source for precision resistor arrays. The lower resistance versions like RES11 are mor something for high precision, though these are missing doubled pins (4 wire connections) at the ends.
