Out of boredom here is another attempt at creating a (scuffed) 10V reference from the 2DW23X
This one uses an LM35 and a very simple proportional feedback circuit to achieve <0.1C of stability. Temperature coefficient is ~10ppm/K, most likely due to the resistors chosen being typical pullup resistors. Surprisingly good for randomly selected devices.
Newer devices seem to be 6.4V to 6.5V typical, so an equivalent 6k:11k gives a very good ~10V output.
I don't have an LNA to measure noise so I cannot attest to it yet, but measuring with respect to an LM399 reference gave ~7uV RMS during the most stable period.
There were random jumps which are probably temperature or other influences. It is probably not (very) insightful since the data was acquired with a ~4.5 digit meter and many random jumps are present, either due to temperature or other influences.
Unfortunately, the reference mysteriously died ~5 days after initial power on.
Nevertheless, this has shown that low quality components are capable of making an "ok" reference, so here is another design involving a differential amplifier on the diode voltage, and measuring the voltage difference to a voltage setpoint derived from the zener voltage. This effectively supplants the LM35, and replacing the components with slightly higher quality ones should improve performance by a lot. The circuit board measures 42.5mm*30mm so it can probably be doubly ovenized.
Is it worth it to replace the diff amp with a common inamp such as INA128/9?
Thanks.
