While I was changing my old Ref_1 and Ref_2 references, I reasoned, what's the essence and Progress in metrology of my original design Goals, which in the volt-nuts community is commonly known as the Dr. Frank Reference.
Andreas owns the Merit of having made a groundbreaking improvement on the EMC ruggedization of the LTZ1000 circuit, which in the end leads to the discovery of the noise barrier in 8digit DMMs, making it 9 digits from now on.
My design was driven by my work in the Automotive supplier Industry as a component Manager.
I reduced the whole circuit to the least necessary and cost effective components, i.e. single sided PCB, usage of Standard precision resistors (w/o any overengineered Special parts), stripping off any esoteric and unmeasurable oddities, like Slots, circular rings, cap, multilayer PCB.
The single sided PCB might have a positive physical effect that all solder Joints are on one layer, so that no temperature differences arise, apart from the warming over the wires. In practice, it has no measurable positive effect as well.
My design foresees a magnetic inner Shield, and a 2nd outer Shield providing proper Ground and Guard for improved emc Performance. It also foresees an inner thermal Shield so that all components stay on equal temperature. In DMMs, I also discovered the noise susceptibility created by the fan air draught, so my thermal design deletes this effect as well.
I initially had the Overall 1ppm design Goal for my lab: TC << 1ppm/, stability < 0.5ppm/yr, uncertainty < 1ppm
so I reversed back to the Weston cell era, where volt metrology was done on an odd 1.018V value, and using a KV divider to create 10V out of it.
My design implemented the first decade of a KV exactly for this purpose, so to completely eliminate the timely drift of the resistors, and making full use of the inertial physical stability of the Zener reference.
My design for the volt-nuts community includes a simple resistor divider w/o any special expensive parts, and making the raw 7.2V available at the outside.
This way, you could either use the 7.2V voltage directly with its ultimate stability, or with equivalent stability the 10.000V output for convenience by using any 6 digit DMM for ratio transfer, giving less than 0.5ppm uncertainty for 10V, due to the common low INL of any DMM, see also my original design goal of 1ppm uncertainty.
Later on, it turned out that these simple precision resistors already inherit low enough T.C. matching and timely drift from scratch, so that even this ratio transfer is obsolete.
My design also includes the observation, that no pre aging process is required. You simply bring up the LTZ1000 circuit, let it run for 3 months, and from then on it will only drift on its specific drift rate of typically -0.5ppm/yr. This drift rate is very predictable, to an absolute uncertainty of about 0.1ppm/year, as can be seen from my comparisons over 20 years!
That implies now, that everybody can simply build his own reference group for the BOM cost only, e.g. 4 x 200$, make a one time calibration to the recent 0.2ppm uncertainty, which I transferred from Philipp, and nobody needs to buy these expensive FLUKE references any more. All my DIY references can now be specified as:
TC < 0.02ppm/K
Stability < 0.5ppm/yr.
Uncertainty 0.2ppm
You get for free a 3 fold stability number compared to Flukes 732C.
If you determine the drift rate of your specific LTZ1000, it will absolutely be predictable for its whole Lifetime, with an uncertainty of absolute 0.1ppm for these observed small drift variations.
So, after a one time calibration and a one time drift rate measurement, its specification can be completed to
Uncertainty 0.2 + 0.1ppm over Lifetime
If you have such an Ensemble of 4 references, comparing them against each other, i.e. man with 3 Clocks principle, you will be able to detect any irregular anomaly, and as in my Long termed Observation, it would even be possible to detect and mitigate this said variation of drift rate, probably by another order of magnitude.
This now implies, that in future there is no need any more for any regular Volt calibration for any Instrument!
The zener references are from a Solid State Physics perspective intrinsically stable and predictable, and the metrologists have overlooked and wasted this outstanding property.
I will present my observations to Mr. Palafox from the PTB. He should please assess for correct metrological practice and confirm the one time absolute traceability of my discovery.
A last philosophic view and why we all do this Metrology volt-nuttery stuff.
Everybody strives for an absolute fix point in his life, that is in most cases the partner, where you hopefully have a stable, long-termed relationship.
This is the case for me, as I'm still living together with my wife since 1990, coincidentally the very same year when I acquired my first HP3458A!
From my youth onwards, I always also strived for this absolute fixed point in voltage metrology, i.e. I always wanted to reach out for the absolutely stable voltage references.
So metrology has the same significance for me like this happy relationship to my wife.
This was always a striking argument when I asked my wife whether she allowed to buy a new instrument.
Maybe this is as well another solution for the volt-nuts community
Anyhow, every development has come to an end, and this is obviously the end of my travel into volt-nuttery.
Let's see, what's next.
