Author Topic: Ultra Precision Reference LTZ1000  (Read 1706208 times)
dada and 3 Guests are viewing this topic.
Offline Andreas
Re: Ultra Precision Reference LTZ1000
« Reply #2925 on: May 03, 2020, 04:26:23 pm »
Hello,
I initially had a 2nd LT1037 on the output stage.
The result was massive oscillations.
(The reason for the LT1012 in the second stage).
So obviously you will have to do some additional
shielding between stages with 2 * LT1037.
with best regards
Andreas
The following users thanked this post: hwj-d
Offline notfaded1
« Reply #2926 on: May 08, 2020, 04:46:22 pm »
Anyone seen these before?  I bought a couple just to test out and alter a little.  Some of the parts look ok and some could use replacing but you don't see completed boards very often even if missing the LTZ.
Bill
.ılılı..ılılı.
notfaded1
The following users thanked this post: picburner, CDN_Torsten
Offline SilverSolder
« Reply #2927 on: May 09, 2020, 11:52:38 am »
Bill
Where did you get them?
The following users thanked this post: notfaded1
« Reply #2928 on: May 09, 2020, 12:02:32 pm »
Bill
I assume, here:
https://www.ebay.com/itm/333584715972
The following users thanked this post: picburner, SilverSolder, FransW, notfaded1
Offline picburner
« Reply #2929 on: May 09, 2020, 02:06:59 pm »
You are all really terrible.... I could not resist and I also took a couple :-DD
Offline notfaded1
« Reply #2930 on: May 11, 2020, 04:23:03 pm »
Yep that's where I bought them from @BU508A!  Didn't take long for you guys to buy them all up!   :-DD
I knew this was coming... complete units using new LTZ (I ordered one of these too to try):
https://www.ebay.com/itm/1-Customized-Ultra-Precision-Voltage-Reference-Board-LTZ1000ACH-LTZ1000CH/333594628743
I'm going to add some of my seasoned aged LTZ's to the other bare boards and see if I can improve on the aging time a little.  I've got some PWW to try instead as well.
Bill
« Last Edit: May 11, 2020, 04:42:31 pm by notfaded1 »
.ılılı..ılılı.
notfaded1
Offline picburner
« Reply #2931 on: May 11, 2020, 05:23:06 pm »
If it can be useful to someone, in the attachment, there is the schematic that the seller has used.
The following users thanked this post: CDN_Torsten, notfaded1
Offline chuckb
« Reply #2932 on: May 14, 2020, 10:53:10 pm »
Noopy provided links to his microscopic views of the LTZ1000 chip here -
https://www.richis-lab.de/REF03.htm
In one of the images you could see light coming from the circular Zener junction. That’s very cool. So, I had to explore that.
I made a little pcb with a tall socket for the LTZ1000. It also had selectable bias currents and operating temperature.
My friend Jim has a great collection of top-of-the-line microscopes. He coupled his new Nikon Z6 to the Nikon Metaphot Metallurgical microscope for the following images.
Thanks Jim!
As you would expect, as the current increased the light increased.
Changing the chip temperature from 50 deg C to 95 deg C at 4ma bias made no noticeable change in the light.
For one image Jim minimized all ambient light so we could capture the full 360 circle of light from the breakdown. Half of the light is hidden behind the trace on the top layer.
Offline CalMachine
  • Metrology Nut
« Reply #2933 on: May 14, 2020, 11:03:51 pm »
:wtf:
 :scared:
All your volts are belong to me
« Reply #2934 on: May 14, 2020, 11:11:01 pm »
Interesting how the light appears in "dots" like stars in a nebula.
Guess this is due to imperfections, so some parts of the junction breaks down more than others?
You can imagine how such a process could be electrically noisy...
It would be awesome to record that light with some kind of photodetector and "listen" to it - is the light output noisy like the zener current?
Offline Magnificent Bastard
  • Country: aq
« Reply #2935 on: May 15, 2020, 05:02:11 am »
Also, what might prove interesting is to hit the junction with a LASER-- and watch what happens with the 1/f noise and voltage output.  I've been wanting to do this for a long time, but it seems @chuckb beat me to it, and is pretty much ready to do this test!
The following users thanked this post: SilverSolder, FransW
Offline Kleinstein
« Reply #2936 on: May 15, 2020, 09:21:27 am »
I can also imagine the light may show some fluctuations. Changes are these may correlate with noise in the voltage.
I don't think this is a kind of junction break-down. The more likely mechanism is that the zener diode in the avalanche regime produces hot electrons and some of these can get to the surface oxide / interface. Relaxation of the electrons there can happen with light at some suitable states (similar to color centers).
Normally the idea behind the buried zener is to avoid this effect by keeping the hot electron from reaching the surface. The second point is that they do less harm in the burried zener: this part can still work but is not so visible.
« Reply #2937 on: May 15, 2020, 11:44:14 am »
If the mechanism is due to electrons relaxing and "going back to bed", perhaps taking a spectrum of the light would show something interesting?  (confirming the material, perhaps, and thereby proving the hypothesis?)
Offline Noopy
    • Richis-Lab
« Reply #2938 on: May 19, 2020, 05:40:53 am »
Are you sure?
I´m no expert regarding semiconductor physics but in my understanding z-diodes with this voltage rating work at least to some extend in avalanche breakdown.
In avalanche breakdown accelerated electrons hit other electrons setting them free on a not exactly defined energy level. If the energy level is in the range of visible light their recombination can emit visible light.
This recombination will perfectly happen in the junction area. In my view most of the recombination will happen there.
Correct me if I´m wrong.
Offline Kleinstein
« Reply #2939 on: May 19, 2020, 07:03:04 am »
A agree one the way the zener is supposed to work. However I doubt that one would see light from the buried junction. This would be rather deep inside the silicon so only very little of that light can escape. The normal avalanche process  should also not produce light as the energy from the hot electron is used to generate new pairs. The normal recombination in silicon is without any light and if any it would be in the IR range (~ 1 µm). It would be only if a hot electron recombines or excites some defect in some way.
It usually takes some defects so that an indirect semiconductor like silicon can emit light. The logical position would be the surface or just inside the oxide. My estimate is that the way to the surface should be easier for a hot electron than for visible light. This would be different if the light is in the NIR range.
Offline Noopy
    • Richis-Lab
« Reply #2940 on: May 19, 2020, 10:14:37 am »
I´m not sure about this.
A view days ago I tried to use a big KD501 transistor as a photovoltaic cell.
(https://richis-lab.de/Bipolar02.htm)
Across the base-emitter-junction I got the same current as across the base-collector-junction. It seems there wasn´t significant light reduction.
I agree with you that hot electrons generate new pairs but some of them will recombinate. Otherwise you will get a real breakdown with 0V and destruction of the junction. (I´m not absolutely sure about the last sentence but that would be my interpretation.)
The hot electrons can have a higher energy than you will see while normal current flow in the semiconductor. With "normal" current flow and "normal" recombination you don´t see any light. I agree with that. But in my view there is recombination of hot electrons.
I tried to take a "maximum tilted" picture but you can´t really say where the light is generated:
The following users thanked this post: chuckb, Henrik_V
Offline exe
  • self-educated hobbyist
« Reply #2941 on: May 19, 2020, 11:58:35 am »
How deeply is a buried zener buried? May be the layer above it is thin-enough to be transparrent to the light? May be photons from inner layer somehow re-emmiter from the outer layer? (purelly guessing here, I have zero knowledge about semiconductors)
Offline Simon_RL
« Reply #2942 on: May 19, 2020, 12:20:14 pm »
Hi All,
Please don’t laugh at me for this question. I am a newbie to electronics and have developed a strong interest in metrology. I want to build a voltage reference based on the LTZ1000a and unfortunately I haven’t got the knowledge to design my own circuit yet. Basically I need a reference for a few experiments I want to do as part of my learning process. I have been hunting for a good circuit and came across this circuit board on AliExpress. If some one can please provide feedback on this circuit and advise if it is any good it would greatly appreciate. Unfortunately there isn’t a schematic, but there are clear pictures of the board and silk screen. If this is no good and someone could please pint me in the direction of a good design I would really appreciate it.
https://m.aliexpress.com/item/4000615209128.html?spm=a2g0n.wishlist-amp.item.4000615209128&aff_trace_key=&aff_platform=msite&m_page_id=2033amp-vGQRqGHv_FhCn8pzRV1uSQ1589885700140&browser_id=fcbdcf015c134b0ca64ebcab0b0f18c2&is_c=Y
« Reply #2943 on: May 19, 2020, 01:11:22 pm »
welcome to the volt-nuts section.  :)
Hi All,
I strongly recommend to read this thread from the beginning. You'll find a lot of useful information and designs of a good LTZ1000 based reference.
Here are some examples:
LTZ1000 based on the design of Dr. Frank:
https://www.eevblog.com/forum/metrology/ultra-precision-reference-ltz1000/
https://github.com/pepaslabs/dr-frank-ltz1000
TiN's KX-reference:
https://xdevs.com/article/kx-ref/
MX reference from user ManateeMafia
https://www.eevblog.com/forum/metrology/mx-reference/
Lot of work lies in front of you.  :-/O   ;)
« Last Edit: May 19, 2020, 02:25:06 pm by BU508A »
The following users thanked this post: Simon_RL
Offline Simon_RL
« Reply #2944 on: May 19, 2020, 01:58:05 pm »
Hi All,
TiN's KX-reference:
Thanks Heaps BU508A. Very much appreciate your assistance.
« Last Edit: May 19, 2020, 02:03:08 pm by Simon_RL »
« Reply #2945 on: May 19, 2020, 04:47:43 pm »
Several things to note here:
1) If the emission is happening underneath an oxide layer, let us remember that we call the silicon dioxide we encounter on an everyday basis "glass". No problems with light getting through centimetres of glass, let alone microns or 100s of nanometers.
2) The assumption made so far is that silicon is the emission candidate. What if it's the dopant? Several common dopants are very strongly associated with visible emission bands (common: arsenic, phosphorous, less common: gallium). There is, admittedly, very little dopant but we're seeing very little light.
3) The assumption that the material is "too thick" for emissions to make their way out.  Remember that we are in the 100s - 1000s of nanometres territory here. At that scale one's assumptions brought from the normal scale world about opacity are quite likely to be wrong.
This diagram of the structure of the buried Zener from the LM399 might be instructive at this stage. It looks to me like the emission is happening well away from the region where the 'buried' junction action is supposed to be going on, perhaps between the outer ring of P- diffusion and the N- substrate or between the cathode and the surface part of the anode P- diffusion.
Offline Noopy
    • Richis-Lab
« Reply #2946 on: May 19, 2020, 05:17:43 pm »
(Attachment Link)
I agree with you in most points except the last one. Be aware that the round thing in the middle of the LTZ1000 is a buried zener and a transistor.
I took also a picture of the transistor working in breakdown:
=> The z-diode has to be around the transistor.
« Reply #2947 on: May 19, 2020, 10:47:51 pm »
I took also a picture of the traor working in breakdown:
Even with my very limited understanding of silicon fabrication I don't believe that is right. The circular structure fits every diagram of a buried zener that I've ever seen, and the structures further out (outside the central region) look much more like what I understand a bipolar transistor to look like on a die. There are more than the two shown in the schematic (I can see 4 things that definitely look like transistors, perhaps even eight), but it is quite common for multiple transistors to be paralleled 'on chip' into a single transistor to allow for thermal balancing, dealing with thermal gradients and the like - exactly what one might expect on a chip like the LTZ1000.
I'd be deeply grateful if someone who is actually properly qualified at decoding dies shots would produce an annotated version of one of the many LTZ1000 die shots kicking about marking out the actual transistors, their CBE connections and so on.
Offline splin
« Reply #2948 on: May 19, 2020, 11:33:05 pm »
Can you buy 'reasonably priced' germanium microscope optics to allow an IR camera to be used to show where currents flow and the current densities?
Offline Noopy
    • Richis-Lab
« Reply #2949 on: May 20, 2020, 07:57:41 am »
Well looking in detail at my own assumptions I have to admit you are right. But I´m right, too.  ;D
The z-diode is designed as descriped in the LM399 diagram. It is connected with the red metal (cathode) and the black metal (anode).
The transistor Q1 is already there with it´s emitter connected to the blue metal in the center. The base is a part of the z-diode (red). The collector is connected from the edge (white).
So there is a transistor which is surrounded by the z-diode but it´s already in the z-diode structure.
The "avalanche lights" confirm this: You can see the base-emitter-junction on the edge of the middle circle whereas the z-diode-junction is buried under the surrounding ring.
Q2 consists of four transistors surrounding the z-diode and Q1 (grey, yellow, blue).
I´m afraid such an optic is unaffordable...  :'(
