It takes 3 days to stabilize.
Once stable, it's so darn accurate and precise.
You need a bit of patience with Rb oscillators. Some of the newer ones do seem to settle quite well in a few days, but others and most older ones can take weeks at least.
There are assorted PIC based 10MHz to 1PPS etc. dividers on LeapSecond.com:
http://www.leapsecond.com/pic/picdiv.htmUsing 1PPS makes it easy to check the long term drift. I was thinking of doing a multiplexer to allow a number of 1PPS inputs to one counter, but never quite got around to it.
If you have a few rubidiums it would be worth running them all for a while to see how well they behave. Some will have better ageing, lower temperature sensitivity, etc. You will also have one as a reference when you adjust another.
They perform better when run continuously.
The environment is a big issue for most rubidiums - particularly temperature, but often air pressure too. Ageing may settle to 1E-13 per day, but temperature sensitivity might be 2E-12 per degree centigrade, and pressure sensitivity near 1E-13 per millibar.
One slight issue with the PRS10 is that all the frequency control is done by a DAC which gives at best about 1E-12 resolution.
What to do all depends on the performance you want to get. It's a rather deep rabbit hole....
