Are there any capacitance measurement instruments that use an integrator to measure capacitance? The idea would be to use the unknown capacitor as the integrator capacitor, connect the integrator input to a very accurate current source, and measure the slope of the integrator output voltage. It's almost like the inverse or complement of a multi slope ADC.
Granted, this would only measure capacitance at DC with 0V bias. I'm just curious if it has been done before or if there are reasons why it would be hard to make accurate. In particular, I'm thinking the integrator output voltage slope measurement might be tricky to perform accurately.
On the other hand, if you want to measure a capacitor that is intended for use in an integrator, this would be a great way to do it, as opposed to an AC capacitance bridge or whatever.
