In a moment of utter madness I've bought another 3458A ... I don't really know why, I guess I'm addicted!
Anyway, it was a faulty unit with a high memory error, which I've already fixed with my previously used FRAM boards for memory and cal data.
It also had a fan that sounded more like a circular saw - now replaced, and the front terminals had been pushed back and broken the plastic screw fixings off of the front panel ... now fixed with a 3d printed part and some epoxy.
But ... the GPIB interface isn't working, nothing detected at all ... I spend bloody ages trying to determine this since my natural assumption was it was a failure with my own-built GPIB interface, but I have now confirmed it works on another 3458A, and another (not of my making) interface also shows the same behaviour.
The connector looks ok and checks out with a continuity tester ... so my assumption is that the GPIB line drivers are faulty ... is that a reasonable place to start?
I haven't started troubleshooting them yet (still waiting for the epoxy to dry!) ... I'm also assuming that it's reasonably easy to see if they are working. I can setup a regular activity and trace the signals through the drivers.
Has anyone else seen these fail?
This unit has a DS75161AN and a SN75ALS160N.
Thanks.
