Some upgrade and tuning for my V7-45.
First, i'm replaced the S5-50 100Meg 0.1% resistor, that out of spec (+0.29%) in electrometric module to precision microwire resistor MRH 100Meg tolerance 0.1%
In fact they have resistance 100Meg -0.04%, I'm compensate this with S2-29V in series resistor 42KOhm.
As result, TIA ranges (1E-7 and 1E-9) tight aligned. And also tight aligned higher bands for integrator. Where this resistor using to calibrate integrating capacitors.
TIA ranges check:
Higher integrating range check:
Second. Where I'm restored with a complete disassembly and assembly the dynamic resonance capacitor DRK-6. The integration capacitor which is installed on it was changed their capacitance, and meter need calibrate this capacitance. The calibration of this capacitor is carried out by the method of supplying a charge 1E-10C and setting the switches in the instrument. For supply a charge I used differentiator from my
NK4-1.
As a result, checking with the
NK4-1 lower ranges wich using this capacitor showed full compliance with the specification with a good margin.
Lower integrating ranges check:
And last point check, where readings should correspond to 20 ±8 lsb.
Third.
As you can see, my instrument has been replaced with a new backlit display. The display was purchased from the Display Unitary Enterprise.
But backlit module is DIY. To build backlit module I'm use the light guide and leds from cracked "slim" notebook display.
DIY backlit module with new display
For powering this backlit module I'm build the voltage multiplier and constant current drive based on jfet. That mounted on outguard powersupply board.
Now the project for the modification and study of this wonderful instrument can be considered closed and I started work on the next interesting project. Soon I will start publishing results on it.
(Spoiler: this is very hard restoration projects for V7-57/1 and V7-57/2 electrometers)
