I have three related questions:
(a) What are your go-to switching matrices for switching with better than 10uV thermal EMF?
(b) Does anyone have any leads on the documented behaviour of relay contacts / contact materials when switching low voltages / currents?
(c) Failing off-the-shelf solutions, are there any go-to designs for low voltage switching (i.e. uV with max 5V) into high-ish impedances (i.e. 10M ohms)?
I'm looking for 25, 50 and 64 channel matrices - but only the 64 channel is critical. All leads welcome
TIA, Alan
