Author Topic: Fluke 5500/CAL - MET/BASE 7  (Read 576 times)
Offline dcmxxTopic starter
  • Country: mx
« on: November 12, 2024, 04:02:42 am »
I own a Fluke 5500A MFC that i got some time ago. The calibrator was repaired with help of one member of the forum, and I posted the result in other thread.
Currently the calibrator it's working well. But recently i got a 5500/CAL license disk, and I'm wanting to install the software to use it to control the 5500A calibrator.
I haven't found online any installer for the MET/BASE 7 that as I understand is the main part of the software.
I tried to contact Fluke Calibration to see if the could provide me the requiered installer, but the claim that this software is no longer supported, so the couldn't help me.
I'm looking if someone has the required installer, or any hint to any place where I could get the software
