On the face of it, the AQY221N2M as it appears to have the lowest typical leakage at the highest voltage, although they all seem to match by the time you get below 5V... However the CRITICAL spec is the 10nA Maximum. There is little information there, so this might apply at the upper end of the operating temperature range, but might not.
It looks as if you can get the manufacturer to select for <1nA maximum leakage, but your best bet would probably be to purchase a few standard parts and hand select yourself for the lowest leakage at ambient temperature and target voltage.
