I had a 332 and gave it away. It was great when it was the only reference I had, but took up too much space and was too heavy to lift. Hint- never connect one to anything that can supply current, like a battery. Smoke will follow.
Never seen a 732 in any condition that I can afford, and anything less than three references is insufficient.
I maintain three 731s and they do quite well, but be sure to service them. My long term success with batteries has been poor, so I replace the batteries with a bunch of capacitance in parallel with a zener, so it looks like a battery of the correct voltage. I don't find much change when power cycling a 731, so I don't worry about it if the power goes out. You can adjust the reference current a bit and achieve way better tempco performance than factory, if you have the patience to test it for a week or two.
