My 2 cents: I picked up the Leo Bodnar unit to have something to check/calibrate my function generators and frequency counters and also as a possible 10MHz standard for devices with an external clock input. None of them go beyond about 10 digits, so I don't think I would classify any of it as metrology-grade. I didn't want the ebay specials, and I didn't want to spend $1k, so the dual-output Leo Bodnar unit hit the sweet spot for me personally.
It is handy to be able to generate other frequencies with high precision, even if nothing else to sanity check devices at the full range of supported frequencies.
However, due to the slightly clunky software and minor limitations of the dual-frequency model, I would not suggest using it on a daily basis in your workflow to generate a lot of different frequencies quickly.
Ultimately I ended up not using it permanently as a distributed 10MHz standard, as all of the equipment I have is good enough without it, and furthermore I didn't like the idea of trusting a single source. So if things disagree later, I check check into it at that time.
