It could be convenient to have 2 settings for the protection resistor. A relatively low one (could be a light bulb) for low noise and much igher resistor to connecto to a new source. This would not just protect the amplifier, but also the DUT from too much of a current spike. LTZ1000 references without extra protection tend to not like the current spike from charging a larger capacitor. A drop at the output tends to cause a spike in the heater power and thus can take some time to recover.
If really needed one can use a pair of depletion FETs for a relatively low resistance current limit. E.g. an SK2145 (cheap, small dual JFET) would give some 120 ohms and 5 mA current limit (the values depend on the threshold).
