The 'advantage' when presenting zero ohms for a *4 wire* measurement is that the current flow from the stimulus/source terminals does not pass through the meter terminals in any configuration. This reduces possible measurement errors.
Of course thermal emf errors could still be present, depending on the materials used to make the connector plate; but that's another rabbit hole to fall down....
Waz
