this doesnt bitbang gpio, it enables 100mhz PLL output on one pin and modulates its frequency = FM modulated radio transmitter
Had not checked up on that, so it is possibly to modulate the internal PLL, there must be more then one presumably, VGA etc.
On ST devices one cant modulate PLL, registers is locked. Maybe one could modulate the RCO but the range is probably to small.
should be doable with preempt kernel to avoid jitter or you could reuse DPI video interface (parallel video), DPI simply dumps contents of the framebuffer into gpio pins, only problem might be blanking (unless you can set blanking/backporch to 0 on the pee)
But reading the "real time" pages over Linux there is ton's of things that in the end seams to block Linux kernel from become a "true
(what ever that is) a real, real-time "thing". Seams to be sort of a hack or another...something... well i don't know jack shit
abut Linux...but anyway...
https://rt.wiki.kernel.org/index.php/HOWTO:_Build_an_RT-applicationfrom hackaday:"With a PREEMPT_RT Linux kernel you can get (worst case) ~150 microsecond determinacy from user space C/C++ code on the RPi 1."
https://github.com/raspberrypi/firmware/issues/497 has a scope screenshot, looks pretty good
But that's terrible figures!
I hope zeo is a long term project, and not a ploy to get rid of old chips , or last scream before Avago kills whole thing.
Hmm, if they had done this with the 2836 chip instead and let one core....
... even if all code and data would had
run from level1 cache this cpu is still not deterministic....No? Yes?
In September 2014 English schools will need to meet the requirements of the new National Curriculum for computer programming. This aims to provide a high-quality computing education and to equip pupils to use computational thinking
and computer programming creativity to understand and maybe change the world!
Is'nt it kind of cheating badly to let kids of today start out by having an entire OS ready to learn coding?
Should'nt they have to go the hard way learning coding by writing the actual OS them self's?
Arn't the whole point of learning something is by doing it from scratch?
How are they going to change the world with probable determinism of 150us, +/-100us?
How far can a kid cheat and still get a grade? Why is teachers helping kids to cheat? Cant teachers write assembler?
Is'nt the requirement to write assembler a must for a teacher?What is the point of this National things UK politicians
slammed through their parliament?!...... Im confused!
