Author Topic: [Atmel studio] won't accept !==  (Read 9783 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: July 10, 2018, 01:30:56 pm »
if (ADC_array_position !== ADC_array_end)
The compiler fails saying that there is nothing before "="
Offline ljwinkler
  • Country: ie
    • LJ Winkler's blog
Re: [Atmel studio] won't accept !==
« Reply #1 on: July 10, 2018, 01:32:54 pm »
You can't have !==.  It's either != (not equal to) or == (equal to) :)
Offline Fred27
    • Fred's blog
« Reply #2 on: July 10, 2018, 01:33:54 pm »
You would happen to be a JavaScript developer, would you?
  • Global Moderator
« Reply #3 on: July 10, 2018, 02:20:04 pm »
Nope, apart from a short foray into BASIC  it has been C all the way.
== is to test one thing is equal to another, I was just making the assumption that I could invert it. presumably != is a dedicated "not equal to" operator.
Offline wraper
  • Country: lv
« Reply #4 on: July 10, 2018, 02:22:52 pm »
I find it very strange that you never used != before.
Offline ljwinkler
  • Country: ie
    • LJ Winkler's blog
« Reply #5 on: July 10, 2018, 02:24:01 pm »
In this case you could use:  if !(ADC_array_position == ADC_array_end)
Offline mbless
« Reply #6 on: July 10, 2018, 02:42:43 pm »
It's just like >= and <=. There's only 2 symbols.
Offline JPortici
« Reply #7 on: July 10, 2018, 03:47:20 pm »
same. i can see you logic, but in C logical operators are either one or two symbols.
if i may.. i suppose "ADC_array_end" is something like "size of array".. like if you declare array[16] then ADC_array_end=15.
if this is the case i suggest you use either
#define ADC_ARRAY_SIZE 16
int ADC_array[ADC_ARRAY_SIZE];
if (ADC_array_position >= ADC_ARRAY_SIZE) {
or
int ADC_Array[16];
int ADC_Array_End = 15;
if (ADC_array_position  > ADC_Array_End) {
for the unlikely (but very possible) situation where you increment ADC_array_position , but for some reason it skips ADC_array_end
Offline Sal Ammoniac
« Reply #8 on: July 10, 2018, 04:05:59 pm »
That won't work either. This does:  if (!(ADC_array_position == ADC_array_end))
Complexity is the number-one enemy of high-quality code.
Offline james_s
« Reply #9 on: July 10, 2018, 04:15:22 pm »
!= is a very common operator used in quite a few languages to indicate inequality. It surprises me to hear someone got past the "Hello World" stage without encountering it. I have yet to encounter a 3-character operator.
Offline ejeffrey
« Reply #10 on: July 10, 2018, 04:23:20 pm »
In C (and most languages) you don't ever invert operators, only values.  You can't do something like !< or !>= either.  != is a separate operator from == that has the opposite value, but one isn't defined in terms of the other.
Someone asked about javascript because javascript has two "equality" comparison operators, == and ===.  So those two operators have inverses that are != and !==.  Again these are not syntactically created by applying inverse to the == and === operators, they are operators in their own right.
  • Global Moderator
« Reply #11 on: July 10, 2018, 05:25:14 pm »
Nope, i have never had to use != before. I am now using ">" anyway, the problem was the last one in many i was looking at in writing some new code to run a project in a very different way to how I normally do it.
Offline exit_failure
« Reply #12 on: July 10, 2018, 06:13:41 pm »
In C/C++ there are the bitshift and assign operators:
<<= and >>=
a <<= 2
is the same as
a = a << 2
« Last Edit: July 10, 2018, 06:16:31 pm by exit_failure »
Offline westfw
« Reply #13 on: July 10, 2018, 09:09:00 pm »
Fortran has logical operators up to 6 characters (heh.  2nd time I've had cause to mention fortran in the last couple of days.)".and.", ".not.", ".nequv."  (there are ".le." equivalents for the standard comparison operators as well)
Cobol apparently has "IF WS-NUM1 IS GREATER THAN OR EQUAL TO WS-NUM2 THEN", but since this is an EE forum, we can be excused for not ever having seen any cobol...  (and I don't think even cobol coders actually WRITE code like that.)
« Last Edit: July 10, 2018, 09:13:37 pm by westfw »
Offline glarsson
« Reply #14 on: July 10, 2018, 09:27:58 pm »
In Forth one of the standard "operators" is */MOD that performs a multiply and division (with intermediate results as double precision) returning both the result of the division but also the remainder.
Offline Monkeh
« Reply #15 on: July 10, 2018, 10:19:57 pm »
Have you considered actually reading a book on C? Obtaining some form of formal programming education? ... reading basically any code in the wild?
Offline james_s
« Reply #16 on: July 10, 2018, 11:01:06 pm »
Heck != is so ingrained that I see it used in casual conversation, usually by people who have some exposure to programming but not necessarily professional developers.
The following users thanked this post: wraper, Frank
Offline andersm
« Reply #17 on: July 10, 2018, 11:15:30 pm »
<<= and >>=
C++20 will also add the three-way comparison "spaceship" operator <=>.
Offline Koen
« Reply #18 on: July 10, 2018, 11:21:58 pm »
Offline sleemanj
  • Professional tightwad.
« Reply #19 on: July 10, 2018, 11:29:28 pm »
Weakly typed languages (for example, PHP and Javascript) often have both "==" and "===", for example
  1 == true
  1 === true
give different results.
« Reply #20 on: July 11, 2018, 12:17:51 am »
"/:=", "divide and becomes", an assigning division operator in Algol 68 which assigns ENTIER(left/right) to left and returns the remainder of left/right as its result. So:
REF INT remainder;
REF INT left := -7;
INT right = 3;
remainder := left /:= right;
leaves:
remainder = 2
left = -3
right unchanged
And no, I never found a use for it in real life. I suspect that the motivation for the inclusion of the operation was the fact that a lot of processor architectures at the time implemented division so that the dividend and remainder ended up in two registers and they wanted an efficient way to exploit this when compilers weren't smart enough to optimise away a seperate pair of division and remainder operations into one 'divide with remainder' opcode.
Offline helius
« Reply #21 on: July 11, 2018, 12:35:43 am »
!ErrorHasOccured() ??!??! HandleError();
Trigraphs are great! A lot of the IOCCC entries make heavy use of them: http://www.ioccc.org/years.html
Offline Leiothrix
« Reply #22 on: July 11, 2018, 02:51:34 am »
Powershell.  It doesn't use a symbol like == for equality, it uses -eq.  Powershell also has operators like -contains, -notmatch, and a pile of others.  Typical Microsoft thinking at work.
Offline Bassman59
  • Yes, I do this for a living
« Reply #23 on: July 11, 2018, 03:21:37 am »
That’s because you’re writing C, not Verilog.
This is one of the reason why I think people who say, “If you know C, you’ll be able to pick up Verilog in no time!” Yeah, sure, despite the fact that the two languages serve different problem domains.
Here’s a fun bug that baffled me for a little bit. I was doing a project that had an 8051 talking to an FPGA. And for the micro code, I wrote something like:
if (foo /= bar) {
And wondered why it compiled, linked, but didn’t work.
Offline Monkeh
« Reply #24 on: July 11, 2018, 03:26:28 am »
Powershell.  It doesn't use a symbol like == for equality, it uses -eq. ...  Typical Microsoft thinking at work.
Typical Microsoft thinking?
-eq is an integer comparison operator which probably goes back to the early 1970s. ie. pre-Microsoft. You may find shells are a more varied world than you expect.
