The PCB will be apparent and its aesthetic is very important :
-Having jumpers for each mcu will not look nice.
-The pcb is only 8mm wide, and I could not find an mcu with a shape that fit the constraints. I spent hours looking at datasheet of leds drivers, but I could only find one that may suit (using 2 of them plus some IO on the PIC to drive the 24 leds), but in the end it is not really more handy (+more expensive components which are harder to source) than using 3 pics.
-Of course, the MCU are QFN and can not be programmed on sockets.
The only problem with the 3 mcu solution is that I don't find a way to have ICSP.
Of course, I could proto with DIP PICs, and use some UQFN20 socket (I could not find where to buy them, I guess you have to DIY one ?), but I'd like the device to be hackable (it will be open soft / hard).
Another possibility I have is to power the device with the normal PSU, and have 3x3 small apparent pad for mclr/icspdat/icspclk. I could then make a icsp to pogo pins adapter. But I'm still open to any idea
