Author Topic: Does grounding the reset pin of the AVRISP2 damage it ?  (Read 2015 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: July 07, 2014, 02:09:32 pm »
Possibly a stupid question but my AVRISP2 programmer no loger has so much as a light on it and won't show as connected to the computer. Last stupid thing I did to it was to ground the reset pin of the MCU with the AVRISP2 connected.
Offline nuhamind2
  • Country: id
Re: Does grounding the reset pin of the AVRISP2 damage it ?
« Reply #1 on: July 07, 2014, 02:35:11 pm »
It could be since the programmer need to pull the reset line high after each transfer.
  • Global Moderator
« Reply #2 on: July 07, 2014, 02:37:39 pm »
That is what I thought although if the programmer uses an open collector type output then it should not do any harm, but all signs say that it's now a dud. I have a new one on order
  • Global Moderator
« Reply #3 on: July 07, 2014, 04:44:08 pm »
well turning off power to a cannected avrisp resets the circuit so maybe it pulls high
