They say it should be : RT8223MGQW
As the
datasheet says, the difference between RT8223M
GQW and RT8223M
ZQW is in the lead plating only; former (G) is "Green (lead and halogen free)", and the latter (Z) is "ECO (ecological, lead and halogen free)". Electrically, they should be perfectly equivalent and interchangeable; the difference only matters to those who manufacture lots of devices using these chips, I think.
I think it is this one: https://www.aliexpress.com/item/1005001875405167.html
I think so too, assuming it is a genuine part and not a reject/fake. (As often mentioned here, a lot of ICs sold on AliExpress and eBay are fakes.)
Please note that I am only a hobbyist, and I might be wrong!
After you desolder the old chip, I personally would check the supply voltage and ground pads, if possible, before soldering the replacement chip.
