[quote author=FrankBuss link=topic=88483.msg1214330#msg1214330 date=1495384769]
There are many examples on the web. Some interesting ones are which you can't write in C or C++, see for example this article and contracts.This article starts from building a storage stack and checking for stack overflows. It may be useful in debugging. However, even in C, you can use macros which will insert checks during debugging. Then you can re-define the macros, so that all the checks are removed for production.
What is important to me, I don't perceive that doing checks is a problem worth addressing. Imagine, you have life critical application, your patient is dying and your stack overflows over and over again. Would it really matter if the patient died because of a reset by bloody unchecked exception in C code, or ... because Ada caught the condition and organizely reported it to a software handler which happily reset the chip.
<disclaimer>I never participated in life critical projects.IMHO, the real problem is how to design the firmware so that the storage stack never overflows - analyze timing paths, execution flow, and make sure that the adverse conditions never happen. This, surely, is not related to any language. But since the stack never overflows, who cares if there's a check for the overflow or not.
However, to make sure everything goes as planned, I need a language which cooperates and does exactly what I say. If Ada inserts a bunch of checks on my timing critical path, upsets the timing and destroys my safety mechanisms, I don't want to be the one fixing the mess. Worse yet, what if Ada does such thing unpredictably, just because I made a small change which caused extra checks to appear. And this all a day before production deadline? I better go with full control and C (or similar), or even assembler if needed.
Post-conditions are not easily possible with C++.
"try" can do it in C++. In C, you can encapsulate your block into a function call.
... there are interesting studies, like this, which compares C and Ada for the number of bugs per lines.
It is a very interesting study. I'm not sure it was because of Ada safety features, or because of the overall verbosity of the language. C is somewhat cryptic and often perceived as unfriendly. I suspect, if they compared C to Pascal, the result would be similar, although there's no safety in Pascal. I do like Pascal better than C, but unfortunately it isn't used much.
Maybe you should write some Ada programs, too, to see if it is just snake oil or if it helps you.
My interests are more at lower levels. When I was young I had a book on Algol-68, which I found fascinating at a time, but then I moved from high abstractions to physical realities, for better or for worse ...
I wish you luck in the Ada contest.
