Well OK I understand, you are just looking at the OVR flag clear procedure, which is probably the same in SPI in I2S modes given they refer you to this section.
However, why do you want to clear the OVR flag?
"few people care for the overrun flag"; well then, I'm one of those "few" people. It is a serious error condition which indicates unrecoverable data loss, and it's most trivial to enable OVR interrupt and attach the error reporting function there, job done, no need to ever look at the flag. I normally enable all possible error interrupt sources, let them end up in the same handler, and there dump error code and all relevant status registers to UART or whatever, maybe once a second so you can attach the cable and see.
Do not depend on planned overruns which you then clear. Obviously in some cases you don't care about the data, and you can just let it overrun, but when the data matters, you don't want overruns at all; and being the SPI master yourself, preventing the overruns 100% is trivial timing work, it's your task as a programmer to guarantee, leaving the OVR flag as error detection mechanism only.
So I think recovery sequence is irrelevant then. For the same reason, I don't use timeouts for core functionality where timeout could be only triggered for two reason: colossal fuckup by me, or actual silicon failure. Sure, people love to throw around unhandled or poorly handled timeouts everywhere, but recovering from serious failures is hard. Do it well, or don't do it at all. (Latter usually works.) But even if you don't try to recover, do check for such failures and add a handler which reports a helpful error code, instead of the software starting to act randomly.
SPI master is deterministic and you have all the control. Having FIFO of 1 word, you don't need to loop on RXNE, only single event can happen. Read it out before the next one, guarantee this by code design and you are fine.
And if you don't have time to do that, then that's what DMA is for.
