EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Microcontrollers
not to be silly about two quick VDD&VSS questions
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: not to be silly about two quick VDD&VSS questions (Read 147 times)
0 Members and 11 Guests are viewing this topic.
sparkydonkey
Contributor
Country:
on:
Yesterday
at 10:53:40 am »
I correctly assume that its always a symmetric ratio so if your MCU had two VDD pins then theres supposed to be two VSS pins equally as well, right?
and likewise to that I assume that even if the first VDD pin was for 2.5V but the second one was for 3.3V, the two VSS nevertheless don't care which is which?
Logged
aeg
Frequent Contributor
Country:
Re: not to be silly about two quick VDD&VSS questions
Reply #1 on:
Yesterday
at 11:08:54 am »
Especially with MCUs now often having separate Vcore and Vio supply pins but modest power consumption and low pin count packages, there may be a single ground pin but multiple supply pins.
Generally all grounds will be connected to the substrate and should be at the same potential.
Logged
sparkydonkey
pcprogrammer
Super Contributor
Country:
Reply #2 on:
Yesterday
at 11:16:27 am »
aeg beat me to the punch, but I present valid examples.
I don't think your first assumption is true. For instance the Allwinner F1C100s has multiple VCC and VDD pins, but only a single ground pad. Same for the T113-S3 and T113-S4. I'm sure there will be plenty more examples of MCU's having a different number off supply pins versus ground pins.
The second assumption is valid though. Ground (VSS) is the 0V potential and carries all the current from the supply voltages back to the supply.
Logged
FNIRSI 1013D Firmware repository
Hantek DSO2000 schematics
Anlogic AL3-10 FPGA reverse engineering
sparkydonkey
Xiamatsu
Contributor
Country:
Reply #3 on:
Yesterday
at 06:09:52 pm »
Most often, yes, paired conclusions are made side by side, most likely for the convenience of wiring the installation of filter capacitors.
For large chips with a large number of pins (BGA for example) It's different there.
Last Edit:
Yesterday
at 06:12:36 pm by Xiamatsu
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Microcontrollers
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
