1802 | RCA | ? Most instructions take 16 clocks (6.4μs), some, 24 (9.6μs). 2.5MHz @ 5V. |
8080 | Intel | ? (still waiting for information) |
8088 | Intel | 10 bus cycles or 40 clocks(?) (B)+(C) (still waiting for further information) |
8086 | Intel | WDC says 182 clocks max total latency. * * * * * (still waiting for information) |
Z8 | Zilog | IRET (E) takes 16 execution cycles. I don't know how many clock cycles per execution cycle. 8MHz? |
Z80 | Zilog | 11-19 clocks (B)+(C) depending on mode, or 2.75-4.75μs @ 4MHz. RETI (E) is 14 clocks, or 3.5μs @ 4MHz. |
Z8000 | Zilog | IRET (E) takes 13 cycles in non-segmented mode, and 16 in segmented mode. I don't know if that's instruction cycles or clock cycles. |
8048 | Intel | (?) return (E) is 2.7μs @ 11MHz |
8051 | Dallas | 1.5μs @ 33MHz (52 clocks) latency |
8051 | Intel | 1.8μs (C) min @ 20MHz. 5.4μs (A)+(C) max total latency @ 20MHz. (3-9μs @ 12MHz.) Interrupt sequence (C) and return (E) take 4.6μs @ 20MHz ST |
80C51XA | Philips | 2.25μs for interrupt+return (C)+(E) @ 20MHz. ST Instructions 2-24 cy, or 0.1-1.2μs. Avg 5-6 cy, or around 0.27μs. |
KS88 | Samsung | 3μs for interrupt+return (C)+(E) @ 8MHz ST Instructions 6-28 cy, or 0.75-2.5μs. Avg 11 cy, or 1.38μs. |
78K0 | NEC | 4.3μs for interrupt+return (C)+(E) @ 10MHz ST Instructions 4-50 cy, or 0.4-5.0μs. Avg 15 cy, or 1.5μs. |
COP8 | National | 70 clocks (7 instruction cycles). RETI (E) is 50 clocks (5 instruction cycles). (7μs & 5μs @ 10MHz) |
μPD78C05 | NEC | RETI (E) takes 13 or 15 clocks (2.08 or 2.4μs at 6.25MHz) |
μPD70008/A | NEC | sequence (C) takes 13 or 19 clocks. Return (E) takes 14 clocks. Instructions take 4-23 clocks each. 6MHz in '87 book. |
V20 | NEC | RETI (E) takes 39 clocks or 3.9μs @ 10MHz in '87 book. Instruction set is a superset of that of 8086/8088. |
V25 | NEC | ? (still waiting for information) |
68000 | Motorola | 46 clocks or 2.875μs minimum @ 16MHz (B)+(C)?. Has a very complex interrupt system. |
6800 | Motorola | (C)=13 clocks, including pushing the index register and both accumulators. RTI (E) takes 10 clocks. 2MHz. |
6809 | Motorola | (C)=19 clocks. Stacks all registers. RTI (E) 15 clocks. 2MHz (8MHz/4). FIRQ-RTI take 10 & 6 clocks, & work more like 6502 IRQ-RTI. |
68HC05 | Motorola | 16 clocks typ (8μs @ 2MHz) |
68HC08 | Motorola | Instructions 1-9 cy, or 0.125-1.125μs. Avg 4-5 cy, or around 0.55μs. |
68HC11 | Motorola | (C)=14 clocks. RTI (E)=12 clocks. Total for interrupt+return=8.75μs @ 4MHz (16MHz/4). ST Instructions 2-41 cy, or 0.5-10.25μs. Avg 6-7 cy, or around 1.6μs. |
68HC12 | Motorola | 2.63μs for interrupt+return (C)+(E) @ 8MHz. ST Instructions 1-13 cy, or 0.125-1.625μs. Avg 3-4 cy, or 0.45μs. |
68HC16 | Motorola | 2.25μs for interrupt+return (C)+(E) @ 16MHz. ST Instructions 2-38 cy, or 0.125-2.375μs. Avg 6-7 cy, or around 0.4μs.
PIC16 | Microchip | (C)=8 clocks (2 instruction cycles), and RETFIE (E) is also 8 clocks; but this doesn't even include saving and restoring the status register. That's an extra, rather mickey-mouse operation. 20MHz Most instructions 4 cy, or 0.2μs. |
TMS370 | TI | 15 cycles (3μs) min (C), 78 (15.6μs) max (A)+(C), and a cycle is 4 clocks (200ns min)! 20MHz. RTI (E) is 12 cy (48 clocks or 2.4μs). |
TMS7000 | TI | (C)=19 cycles min (17 if from idle status) 5MHz, 400ns min cycle time (IOW, interrupt sequence is 7.6μs min, 6.8 from idle.) RETI (E) is 9 cycles, or 3.6μs @ 5MHz. |
ST6 | STM | 78 clocks min, or 9.75μs @ 8MHz to fetch interrupt vector. More to reach first ISR instruction. RETI is 26 clocks, or 3.25μs. |
ST7 | STM | 3μs for interrupt+return @ 8MHz. ST Instructions 2-12 cy, or 0.25-1.5μs. Avg 4-5 cy, or around 0.55μs. |
ST9 | STM | External IRQ best case: 1.08μs @ 24MHz. NMI best case: 0.92μs. internal interrupts best case: 1.04μs. 2.25μs @ 24MHz for interrupt and return ST Instructions 6-38 instruction cy, or 0.5-3.67μs. Avg 17 cy, or around 1.4μs. |
ST9+ | STM | 1.84μs @ 25MHz for interrupt and return, ST Instructions 2-26 instruction cy, or 0.16-1.04μs. Avg 11 cy, or around 0.9μs |
H8/300 | Hitachi | 8/16-bit: 2.1μs @ 10MHz for interrupt and return ST Instructions 2-24 cy, or 0.2-3.4μs. Avg 5-6 cy, or around 0.55μs.
M16C M30218 | Mitsubishi Renesas | 18 cy min (C), or 1.125μs @ 16MHz w/ 16-bit data bus. 50 cy max (A)+(C). REIT is 6 cy, or 0.375μs. Dual register sets like the Z80. Max instruction length 30 cy. |
CIP-51 | Silicon Labs Cygnal | μC p/n C8051F2xx) total latency 5-18 cy or 0.2-0.72μs @ 25MHz. RETI takes 5 cy, or 0.2μs. This is the only one I have data on here that gives the 6502 below any competition. |
65C02 | WDC | Normal latency (C) 7 clocks (0.35μs) min, 14 clocks (0.7μs) max (A)+(C). RTI 6 cy (0.3μs). 20MHz. Instructions 2-7 cy, or 0.1-0.35μs. Avg 4 cy, or 0.2μs. Special case: IRQ from WAIt instrucion with interrupt-disable bit I set: no more than 1 cy (0.05μs!) |
