Author Topic: "Make With Ada" Competition  (Read 19776 times)
Online NANDBlog
Re: "Make With Ada" Competition
« Reply #25 on: June 22, 2016, 11:38:03 am »
OK, let me know when  there is dynamically typed, event driven, visually programmable, subjective COBOL for ARM, than maybe I will not use C.
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #26 on: June 22, 2016, 11:41:53 am »
another C/C++ vs others combats, "everybody should drive automatic transmission car because manual transmission car you can give the wrong output" :palm: do you see any C/C++ embedded competition to increase awareness? nope because everybody are already well aware what C/C++ can do, except some champions in this thread. how many time do i have to tell, want a runtime checking? program in Basic! :palm:
if something can select, how cant it be intelligent? if something is intelligent, how cant it exist?
Offline Xenoamor
  • Country: wales
« Reply #27 on: June 22, 2016, 12:08:21 pm »
Is this not needlessly verbose?
package body Program is
   procedure Run is
   begin
      loop
         null;
      end loop;
   end Run;
end Program;
I.e.
void run(void)
    for (;;)
Looking more in depth I could see why this would be appealing for industrial machinery. It seems harder to 'get wrong'. Seems a little clunky for handling memory addresses directly though
Personally I feel I wouldn't enjoy programming in such a strict language but it's not all about enjoyment
« Last Edit: June 22, 2016, 12:17:16 pm by Xenoamor »
Online Mechatrommer
  • Country: my
« Reply #28 on: June 22, 2016, 12:17:41 pm »
void run(void)
    for (;;)
competition sake i prefer...
void run() { for (;;) {} }
Offline Kalvin
  • Embedded SW/HW.
« Reply #29 on: June 22, 2016, 01:29:10 pm »
void run(void)
    for (;;)
Way too verbose. Just use assembly:
run: ret
Online nctnico
« Reply #30 on: June 22, 2016, 02:51:58 pm »
no:
run: bra run;
Offline Kalvin
  • Embedded SW/HW.
« Reply #31 on: June 22, 2016, 03:00:00 pm »
no:
run: bra run;
Good catch :) This may be less verbose, though:
run: bra $
Online tggzzz
« Reply #32 on: June 22, 2016, 03:51:49 pm »
I haven't cared about verbosity since the 1970s, when I was a 2-fingered typist on a very heavy and literally clunky ASR-33.
Since the 1990s verbosity has been a complete non-issue, given a decent language and a modern IDE. The most frequently typed character is "control-space", which often correctly inserts dozens of characters :)
Offline donotdespisethesnake
  • Embedded stuff
« Reply #33 on: June 22, 2016, 06:36:33 pm »
Adacore are doing the "monetize Open Source tools" business model. To be fair, they developed the code originally, although with a large chunk of public money and on the condition that the code must be GPL.
However, they are very misleading to imply that the only choices are their versions of "GNAT Pro" or "GNAT GPL", and anything else is untrustworthy.
The third version is from FSF that is licensed with a less restrictive run-time exception which we have come to expect for GCC based compilers.
So I would steer clear of Adacore and go to http://www.getadanow.com/
Bob
"All you said is just a bunch of opinions."
Offline westfw
« Reply #34 on: June 22, 2016, 10:36:13 pm »
The absence of LGPL libraries has made me lose interest completely.
And runtime environment.  Don't forget the run-time environment, which can be quite extensive in many languages.
I've come to suspect that the main reason that C has been such a success is that it has such a small (nearly non-existent) runtime environment, and minimal "required" libraries.  If you want to have a Fortran (or Ada) compiler for some system, you have to write an awful lot of relatively system-dependent code, NOT written in Fortran (ie probably written in assembler.)  If you want to implement a C compiler, you can almost get away with putting a C back end on your compiler, publishing an ABI (if none exists yet), and claiming to be done.  Some languages are pretty dependent on having their runtime and libraries NOT be written in the language itself, if you want good performance.  Meh.  Perhaps these days there is a "portable Fortran Runtime environment" written in C...
"Is this not needlessly verbose?"  ...  I haven't cared about verbosity since the 1970s
Wasn't that also about when we stopped equating verbosity with "quality" as well?   I mean, I hear lots of complaints about C and C++, and some of them I agree with and some not so much.   But "a language should really use keywords like "begin" and "end" instead of braces" has never been one of them.
Offline Xenoamor
  • Country: wales
« Reply #35 on: June 23, 2016, 10:01:04 am »
I think the argument is less about typing speed and more about readability
Online tggzzz
« Reply #36 on: June 23, 2016, 10:57:22 am »
Oh, that's your point. Beyond a certain point I agree, but Ada hasn't reached that point. Obviously APL and COBOL represent opposite and unacceptable extremes :)
But in practice the number of characters isn't critical. Much more important is the way the program is structured/architected, the language's ambiguities and gotchas, the coder's personal style/ability (or lack thereof!) and the navigation/inference abilities built into the IDE. The last is ultimately constrained by the language, but the maturity of an IDE is also relevant.
The following users thanked this post: Xenoamor
Offline Kalvin
  • Embedded SW/HW.
« Reply #37 on: June 23, 2016, 12:23:43 pm »
Excellent info,  thanks for the link. From the link provided one can also find Ada for the AVR, Cortex-M3 and some other microcontroller architectures.
Offline Kalvin
  • Embedded SW/HW.
« Reply #38 on: June 23, 2016, 12:34:42 pm »
Ada looks quite verbose compared to C/C++ and some other languages. However, when you think about designing the software, typically you tend to spend quite a lot of time in designing phase (or at least you should be). You may also spend some time in the debugging phase, or much longer time if you didn't spend enough time in the design phase. The writing itself is only very small portion of the process, and the verbosity shouldn't be a problem.  There is a rationale behind Ada's verbosity, as the language and its syntax was designed so that detecting logical and typographical errors is easier to the compiler and the human.
Offline zapta
« Reply #39 on: June 23, 2016, 03:26:35 pm »
This is for example why Ada doesn't have multi line block comments similar to C's   /* ... */
Drain the swamp.
Online Mechatrommer
  • Country: my
« Reply #40 on: June 23, 2016, 06:34:32 pm »
how many times do i have to tell, verbosity and all that human friendly crap, nothing better than Basic! :blah: otoh.. someone mentioned runtime environment, think Java everybody loooves Java, i just dont get the awareness, more so the resurrection of Ada... :blah:
Offline chickenHeadKnob
  • doofus programus semi-retiredae
« Reply #41 on: June 23, 2016, 08:19:18 pm »
Still there is no need to bring up the disadvantages of the old tool when discussing the new tool.
It is perhaps a small pedantic point, but to be correct ADA is the old(er) tool but not by much. It predates C++ by about 2 years or so. I first heard of ADA around 1981 at university. The comprehensive language spec came out in 1983. The first C++ pre-processor  came out around '83 but it was half-baked, the language took some extra years for the compilers and language spec to stabilize.  I would say stabilize guardedly as there has been a sporadic accumulation of cruft in the C++ spec over the the time span. ADA has also been revised but not to the same degree in my opinion. The biggest argument in favour  of ADA is its memory management, a whole class of common bugs is eliminated.
I don't much like either language.
Offline rstofer
« Reply #42 on: June 24, 2016, 11:39:45 pm »
OK, I bought the StM32F7...Discovery board and, sure enough, ADAcore GNAT has support for it.  I'm just starting to look at the package but from what I can see, "Hello World" even when linked with the "small footprint" library is ginormous, on the order of 140k, if I am looking at the correct output file.
Anyway, the board will be here in a few days.  Now what?
Online nctnico
« Reply #43 on: June 24, 2016, 11:43:35 pm »
The size is probably due to the runtime library. You probably have to add lots of code yourself in order to increase the size significantly  >:D
Offline westfw
« Reply #44 on: June 25, 2016, 01:53:32 am »
You're not supposed to care.  You've got 1MB of flash and 16MB of QSPI flash to put your code into.  Plus RAM.
The question is: is that 140k fixed runtime overhead, or an indication of bloated code in general?  If helloWorld takes 140k, how big is a converted "real" application?  And how well does it run?
I'm also in the camp of "that's too big and too slow - it should be smaller and faster", whenever I look at "modern" languages.   But, you know, they also DO STUFF and create applications that would be nearly impossible to write in "bare C" (not to mention that you'd probably be spending all your time "supporting" the infrastructure code you had to write, instead of using those bloated libraries.)
Offline rstofer
« Reply #45 on: June 25, 2016, 04:02:15 am »
The code for "Hello World" itself is quite short - something around 60 bytes (I'm just guessing, the package is on another computer).  The rest is run time and, perhaps, the debug information.  I still need to do a lot of research on how the software is set up.
I want to learn Ada.  No particular reason, I'm not going to work for the military.  But the language is a lot like Pascal and I absolutely love Pascal.  I used it about a dozen years ago with an 8051 clone to create a small control system for a battery powered board.
I'm going to look through the library source code (it is provided).  It's all written in Ada and that's fine but my idea of 'small footprint' may be a lot smaller than the developers'.
Like all ARM devices, the startup code gets out of hand fairly quickly.  There are a number of clocks to set up, there's an FPU to initialize and the I & D caches.  All of this is written in Ada so there's a lot of example code to reference.
I have a lot of experience with bare iron chips and C so I'm not necessarily tied to the Ada runtime.  The GCC toolchain allows Ada to link with any of the other languages including ASM & C.
Offline EEVblog
« Reply #46 on: June 25, 2016, 05:35:20 am »
ADA?  :-//
Were we transported back to the 1980's?
Online tggzzz
« Reply #47 on: June 25, 2016, 05:56:48 am »
ADA?  :-//
ADA is an improvement on many of its successors. (Old joke, first made about Algol-60).
Similar points can be made about Erlang (just look at how many new languages/libraries are trying to emulate its advantages) and Fortran (which still rules supreme in high-performance numerically-intensive computing).
Offline westfw
« Reply #48 on: June 25, 2016, 08:15:51 am »
So ... how does that work?  I would have thought that the sort of type-checking and "safety" Ada is supposed to provide would make low-level initialization nearly impossible without resorting to non-Ada code.
Offline Kalvin
  • Embedded SW/HW.
« Reply #49 on: June 25, 2016, 10:05:59 am »
Could you please elaborate this a bit more. What makes you think that Ada is less suitable for the low-level programming compared to C/C++?
