Author Topic: A faulty pin?...  (Read 3436 times)
Offline Tricka90
A faulty pin?...
« on: October 02, 2013, 06:18:52 pm »
I'm trying to light up a LED with a PIC 16F876 (datasheet: http://ww1.microchip.com/downloads/en/devicedoc/30292c.pdf) on port RA5. The LED just doesn't light up.
I've set TRISA = 0 and PORTA.RA5 = 1 of course.
In the datasheet I found that RA5 is also an analog port, so I set up all port as digital with ADCON1 = 0b00000110 and ADCON0 = 0.
Still the LED doesn't work.
Then I found that RA5 is also a "slave select for the synchronous serial port" so I tried to disabilitate this function with PIE1.SSPIE = 0 and SSPCON.SSPEN = 0.
The LED continues not lighting up.
Do you think I'm doing something wrong? Could it be that pin RA5 is just faulty?
Offline alanb
Re: A faulty pin?...
« Reply #1 on: October 02, 2013, 06:25:46 pm »
If you think  that a particular pin may be faulty have you tried a different pin and updating your software for the new pin?
Also have you checked that there is power to the PIC and that the clock is running etc?
Offline dannyf
« Reply #2 on: October 02, 2013, 07:05:27 pm »
1) take a look at the pins and see what functions, other than gpio, they may have;
2) turn those functions off.
In your case, two additional statements will do.
Offline Tricka90
« Reply #3 on: October 02, 2013, 07:30:08 pm »
Thank you for the answers.
The other pin works perfectly, also the pin on the same port.
The functions of RA5 are the ones I mentioned, I don't think it has other functions
Offline Tricka90
« Reply #4 on: October 02, 2013, 09:13:34 pm »
I use MikroC as compiler
Offline David_AVD
« Reply #5 on: October 02, 2013, 10:39:19 pm »
You need to turn off the analog inputs as they are on by default.  Check the data sheet for the ADCON1 register.
Offline dannyf
« Reply #6 on: October 02, 2013, 10:41:11 pm »
Not sure what "the pin" is. But if other pins on the same port works, then the possibility of a hardware issue has increased.
Offline Tricka90
« Reply #7 on: October 03, 2013, 07:05:34 am »
I'm sorry, I mean all other pinS.  Yes, they do work, all the pins on the same port
Offline AndyC_772
« Reply #8 on: October 03, 2013, 07:22:10 am »
PICs are cheap, so swap the PIC for a new one and try that. If you don't have a spare, order at least 5 today, or 10 if you think you might be doing any future projects with the same device.
Never, ever buy exactly enough cheap bits for a project... you'll end up paying more in shipping for replacements every time something breaks anyway. I always buy at least 'n+1' even of quite expensive bits, and often buy 5 or 10 of something I only need 1 or 2 of. If I need a chip today, chances are I'll need another one next week anyway.
Offline Tricka90
« Reply #9 on: October 03, 2013, 07:51:04 am »
Thank you for all the help.
I must say I'm really really sorry, I made a big mistake: the "faulty" pin isn't RA5...it is RA4 !!!
This pin could also be used as T0CKI, that is Timer0 clock input.
I have disabled the bits, now I have OPTION_REG = 0b100000010, just RBPU and prescaler because I would like to use Timer0 in my program.
Why it still doesn't work? Should I set other bits?
Offline dannyf
« Reply #10 on: October 03, 2013, 08:17:55 am »
RA4 is OD.
Read the datasheet>
Offline adam1213
« Reply #11 on: October 03, 2013, 08:24:33 am »
RA4 is OD.
Read the datasheet>
As the output is open drain you need to setup the LED such that it will go on when you set the output to 0. e.g. connect it to VCC through a resistor.
