Author Topic: AD9850 is it possible to generate a square wave with variable duty cycle ?  (Read 14740 times)
Offline legacy
Re: AD9850 is it possible to generate a square wave with variable duty cycle ?
« Reply #25 on: November 27, 2013, 10:51:25 am »
the output filter should have inductors, differently they must be provide externally.
Offline legacy
« Reply #26 on: November 27, 2013, 10:52:27 am »
See L1,L2
Offline Crazy Ape
« Reply #27 on: November 27, 2013, 11:50:09 am »
Yep, I see em. But I hadn't looked at it at as you seemed to be asking about the modules I linked to. I imagine the modules I linked to are to be designed to be used as part of a bigger design, which would include the filter. The filter specifications are going to change depending on the application, therefore I suspect it's usually left to the designer.
The DDS-60 looks to be a more completed, hobbyist targeted design.
It all comes down to your application.
« Last Edit: November 27, 2013, 11:52:01 am by Crazy Ape »
