Author Topic: LVDS input on spartan6?  (Read 10511 times)
Offline awallinTopic starter
« on: November 20, 2014, 05:43:30 pm »
Hi all,
I want to prototype a counter/timer thingy and have some fast ADCMP604's for the inputs.
They produce an LVDS output that I want to connect via a 'wing' to a PapilioPro/Pipistrello FPGA.
http://www.saanlima.com/download/pipistrello-v2.0/pipistrello_v2_schematic.pdf
How should I choose the pair of pins on the FPGA for my LVDS signal?
Does the LDVS pair need to be something like: LXXP / LXXN, for example will this work on the Pipistrello?
LVDS pos -> WingA_1 -> IO_L51P_M1DQ12_1
LVDS neg -> WingB_14 -> IO_L51N_M1DQ13_1
or can any pair of FPGA pins make a differential pair? and how is that defined as one logic signal in a UCF file?
thanks,
Anders
Offline hamster_nz
Re: LVDS input on spartan6?
« Reply #1 on: November 20, 2014, 06:00:50 pm »
You want to look for a pair of pins that are part of differential input that are close together on the wing header.
In your constraints file you do this (this is on the Papilio Pro):
NET test_signal_p  LOC = "P51" | IOSTANDARD = LVDS_33;
NET test_signal_n  LOC = "P50" | IOSTANDARD = LVDS_33;
And then in you HDL you use a IBUFDS to convert the differential signals into the single ended signal used in the design:
library UNISIM;
use UNISIM.VComponents.all;
  -- Input buffer
i_IBUFDS : IBUFDS
   generic map (
      DIFF_TERM => FALSE,
      IBUF_LOW_PWR => TRUE,
      IOSTANDARD => "DEFAULT")
   port map (
      O  => test_signal,
      I  => test_signal_p,
      IB => test_signal_n
Here are the four pairs I used for HDMI input (I know that it isn't the same as LVDS, but the pin locations are what you need....). Oh and due to PCB layout constraints some of the pairs are flipped around (with the _p connected to a N pin, and the _n connected to the P pin) - it would pay to cross-reference them with the datasheet - but here are four pairs that I can vouch for!
NET "hdmi_c2_p" LOC="P57";
NET "hdmi_c2_n" LOC="P58";
NET "hdmi_c1_p" LOC="P55";
NET "hdmi_c1_n" LOC="P56";
NET "hdmi_c0_p" LOC="P62";
NET "hdmi_c0_n" LOC="P61";
« Reply #2 on: November 20, 2014, 06:44:02 pm »
Thanks for the great reply!
As my board connects to the wing-connector, I can put a terminating 100R resistor across the LVDS pair there - or alternatively use the internal termination of the FPGA? Any opinions on that?
This is roughly what I have, based on the input of a digital-IO board by CERN(ohwr.org).
VREF would come from a 3V voltage reference.
Offline hamster_nz
« Reply #3 on: November 20, 2014, 11:40:42 pm »
You can do internal termination.... with a DIFF_TERM = TRUE constraint:
See the image at the top of page 15 : http://www.xilinx.com/support/documentation/user_guides/ug381.pdf
Online langwadt
« Reply #4 on: November 20, 2014, 11:52:29 pm »
Hi all,
thanks,
Anders
you have to use the pairs LXXP / LXXN
depending on your input levels you might be able to use the LVDS input directly, an LVDS input is a fast comparator
I alway instantiate LVDS input directly, i.e.
IBUFDS  #(.DIFF_TERM("TRUE")) ina (.O (a), .I (a_p), .IB (a_n));
Offline Bassman59
  • Yes, I do this for a living
« Reply #5 on: November 21, 2014, 04:50:41 pm »
Hi all,
thanks,
Anders
To use LVDS or other differential I/O standards, you have to instantiate the proper buffer in the source code and you have to choose the proper IOSTANDARD in the UCF.
